Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
yPlusRAS Error in foam-extend-3.1
Old   August 26, 2014, 14:17
Default yPlusRAS Error in foam-extend-3.1
cdm
cdm is on a distinguished road
I'm having difficulty with the yPlusRAS -compressible command in foam-extend-3.1. When using the mutkWallFunction, the utility does not recognise this as a valid option for the mut field and outputs zero value for yPlus on the wall. I cannot find any different in the execution of the code between OF230 and FE31, and so I wonder if it's not a dependency call issue.
Two questions:
1) What's the different between mutkWallFunction and mutWallFunction? Are they interchangeable without any significant effect?
2) Does anyone know a simple solution to fix the yPlusRAS utility to recognise all included wall functions?
Cheers
cdm is offline   Reply With Quote
foam-extend-3.1, mutkwallfunction, mutwallfunction, yplusras
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
