Exporting particles of lagrangian solvers to Tecplot |
May 3, 2015, 12:08 |
Have you found any solution to this?! Maybe it can be done by writing an ascii file with the x,y,z positions?
Learn OpenFOAM in Persian SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member Complex Heat & Flow Simulation Research Group If you can't explain it simply, you don't understand it well enough. "Richard Feynman" |
Multiphase Lagrangian Particles | moritzhoefert | OpenFOAM | 1 | December 8, 2010 09:48 |
Additional variable for lagrangian particles (dieselFoam) | N. A. | OpenFOAM | 0 | July 16, 2010 11:45 |
How to set correct mass flow rate for lagrangian particles ? | sankarv | OpenFOAM | 0 | April 19, 2010 12:40 |
Problem Exporting to Tecplot | Craig | FLUENT | 2 | July 16, 2008 00:21 |
[OpenFOAM] Whatbs the best way to visualize paticles from lagrangian solvers | sek | ParaView | 2 | September 19, 2007 18:02 |
