Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Surface Sampling
Old   July 22, 2014, 12:23
Default Surface Sampling
AA29 is on a distinguished road
Dear Foamers,
I have an engine case where I need to extract velocities on different cut planes.
To do that I am using sample utility in OpenFoam with a format raw (which gives the coordinates and the velocity components). Later I am plotting the 2D velocity vectors in Matlab. But since the mesh is not an evenly spaced grid , I am having some issues in creating the contours and vectors.
My question is there a way I could get the velocities on a regular grid (like remapping the sampled velocity on an evenly spaced grid)? Or a surface write format which writes the sampled data at regular intervals given a dx , a dy and start and end points? I am aware that line sampling can do that, but I need surface sampling in this case.
Thanks for your time.
AA29 is offline   Reply With Quote
Old   August 6, 2014, 14:12
Well I had to provide a cloud of points using set sampling to get what I wanted.It works but creating a cloud is not fun, especially if the domain is big and we want to sample at many points.
Thanks !
Old   August 6, 2014, 14:22
Another question is that when we provide the coordinates of several points to sample, and say a point A(0.5,0.5,0.5) lies outside our solution domain , then the sample utility does not output any value at that point (I am using "raw" write format).
All I want is that OpenFOAM outputs "NaN" values at all those points which lie outside the domain. Does anyone have an idea about how to accomplish this?
Thanks in advance !
Old   October 26, 2020, 14:18
Bodo1993 is on a distinguished road
Thanks in advance !
Hi, I am wondering if you were able to make OpenFOAM output NAN for the points which are outside your domain. Thanks.
Bodo1993 is offline   Reply With Quote
Old   September 21, 2021, 08:16
Default Sample on array of points
Tom Lauriks
Tom Lauriks is on a distinguished road
I also needed to sample on set of points on a surface and found a solution.
It's possible to sample on a surface drawn in a CAD program (I use blender), which is exported as stl. If you draw the points where you need to sample and connect them as a surface, it is possible to sample on these points.
You can then add to your controlDict (openfoam.com v2012):
planesVelocity
     type            surfaces;
     libs ("libfieldFunctionObjects.so");
     enabled         true;
     writeControl    runTime;//Writes data every writeInterval seconds of     simulated time.
     writeInterval 0.001;
     interpolationScheme cellPoint;
     surfaceFormat raw;
     surfaces
         y0
             type            sampledTriSurfaceMesh;
             surface         y0.stl;
             interpolate     true;
             source insideCells;
     fields
         U
         turbulenceProperties:R
For the setting source I find:
source=insideCells, interpolate=true Per surface point interpolate cell containing it.
https://cpp.openfoam.org/v4/classFoa...rfaceMesh.html . The stl file is located in constant/triSurface
I didn't check thoroughly, but values outside the domain seem missing. I will write a script (Python) to add the missing coordinates and set them to NaN.
Tom Lauriks is offline   Reply With Quote
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Problems with surface sampling mcarpe OpenFOAM Post-Processing 11 November 9, 2012 12:00
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 11:45
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
