Nusselt no. calculation for conjugate heat transfer |
June 21, 2014, 20:42 |
shiv
Rep Power: 14 |
Hi Everyone ,
I am working on chtMultiRegionSimpeFoam solver for simulating a fin tube heat exchanger, I wish to calculate the value of Nusselt number so i have been refering to several threads and came up with an idea to make changes to the wallGradU to calculate gradient of T at the wall patch. But whenever i use this utility i get Code:
Create time Create mesh for time = 0 Time = 0 Reading T Calculating wallGradT Time = 1600 No T Time = 1700 No T Time = 1800 No T Time = 1900 No T Time = 2000 No T End Please help me with this. Referred link: http://www.cfd-online.com/Forums/ope...timesteps.html |
June 22, 2014, 04:24 |
shiv
Rep Power: 14 |
I suppose the problem is because the "T" is in separate folder that is say for 2000 iterations : instead of 2000->T ,i have 2000->regions->T
So can anyone direct me how can i make changes to the path for utility wallGradT. pleaseeeeeee help |
June 24, 2014, 06:36 |
Hello Shiv,
You can refer to the following link on Nusselt number. http://www.cfd-online.com/Forums/ope...lt-number.html As stated, you can edit and make your own utility. - Best Luck ! |
Manual calculation of Heat Transfer Coefficient | TrII4d | CFX | 20 | January 26, 2017 12:40 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
low heat transfer and nusselt number below 1. | amir7 | FLUENT | 9 | April 29, 2012 16:47 |
Syntax errors with Thread Types and Wall Heat Transfer calculation | jcespada | Fluent UDF and Scheme Programming | 2 | March 16, 2012 02:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
