Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
export calculated variable with cuttingPlane
Old   June 16, 2014, 11:59
Default export calculated variable with cuttingPlane
Eloïse
Eloise is on a distinguished road
Hello Foamers,
In OpenFoam 2.2.2, I'm trying to sample surfaces at the end of my simulations. I didn't managed to setup the sampleDict in 2.2.2 version to extract variables on a surfaces so I'm trying another approach: I use the cuttingPlane function in my controlDict (see below).
However, I need to extract both solved variables (like U) and unsolved variables which can be calculated through post-processing commands (like magU). If I write both variables in the cuttingPlane function, only U is printed. Do you know how to have a variable such as magU exported from cuttingPlane function? Or how the sampleDict should be written in OF2.2.2 in order to extract a surface?
Thanks for your help!
Regards,
Eloïse
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
cuttingPlane
    type            surfaces;
    functionObjectLibs ("libsampling.so");
    outputControl   outputTime;
    surfaceFormat   vtk;
    fields          ( U magU );
    interpolationScheme cellPoint;
    surfaces
        z_5m
            type            cuttingPlane;
            planeType       pointAndNormal;
            pointAndNormalDict
                basePoint       (0 0 -5);
                normalVector    (0 0 1);
            interpolate     true;
Eloise is offline   Reply With Quote
How to export single variable of a single surface? zeitistgeld CFX 6 September 26, 2009 07:37
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Export patch profile johndeas OpenFOAM Running, Solving & CFD 5 January 25, 2008 05:27
Problems with additional variable Krishna Premi CFX 1 October 29, 2007 09:19
how to export calculated values to a file colin Fidelity CFD 1 June 5, 2007 05:14
