interphasechangeFoam: strange residual behaviour with keps and kwSST |
June 11, 2014, 23:12 |
Baris (Heewa)
Rep Power: 13 |
Hi to all,
Addition to my above question, i would like to ask one more thing. As you can see in the attached figures, I did calculation using different turbulent models (keps and kwSST) with the interphasechangeFoam. First of all, i initiliazed flow fields for both cases, than for k-eps i used upwind discretization. As seen in the first fig., evertying seems to go well, however after t=0.0145 there are rapid jumping in the initial residual of alpha and P. On the other hand, for kw-SST i used TVD scheme, and as seen in 2nd fig, after t=0.0118 there is rapid decline in the alhpa residual. Could someone have any idea why these rapid and decline take place nearly at the end of the calculation? Thanks in advance. B |
June 14, 2014, 09:58 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Baris,
I've moved this post of yours from the other thread: http://www.cfd-online.com/Forums/ope...g-gnuplot.html - because the question isn't as related to the original topic and it was less likely that you would get and answer to either one of the issues. As for your question on this thread, without more information, I can only guess the following:
Best regards, Bruno |
