interphasechangeFoam: How to add U to Residual plotting with gnuplot? |
June 9, 2014, 01:01 |
Baris (Heewa)
Rep Power: 13 |
Hi to All,
I am trying to plot the residual by using gnuplot. One of the iteration saved in my log file is as follows: HTML Code:
DILUPBiCG: Solving for alpha1, Initial residual = 4.38942e-05, Final residual = 1.79432e-11, No Iterations 1 Liquid phase volume fraction = 0.999624 Min(alpha1) = 0.0663787 Max(alpha1) = 1 PIMPLE: iteration 1 GAMG: Solving for p_rgh, Initial residual = 0.0390795, Final residual = 0.00328955, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.00474834, Final residual = 0.000251044, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.00695737, Final residual = 0.000493905, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.00151405, Final residual = 7.09018e-05, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.00310708, Final residual = 0.000183107, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.000543072, Final residual = 1.95473e-05, No Iterations 2 PIMPLE: iteration 2 GAMG: Solving for p_rgh, Initial residual = 0.00142025, Final residual = 6.74854e-05, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.000205943, Final residual = 7.01413e-06, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.000606703, Final residual = 2.57123e-05, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 8.15515e-05, Final residual = 3.07118e-06, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.000268793, Final residual = 1.01818e-05, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 3.37112e-05, Final residual = 1.29354e-06, No Iterations 2 PIMPLE: iteration 3 GAMG: Solving for p_rgh, Initial residual = 0.000123156, Final residual = 4.13567e-06, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.46604e-05, Final residual = 5.41923e-07, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 5.54985e-05, Final residual = 1.6922e-06, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 6.40674e-06, Final residual = 2.2905e-07, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 2.58142e-05, Final residual = 7.05381e-07, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 2.96623e-06, Final residual = 1.05465e-07, No Iterations 2 PIMPLE: iteration 4 GAMG: Solving for p_rgh, Initial residual = 1.23282e-05, Final residual = 3.02816e-07, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.46768e-06, Final residual = 5.97165e-08, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 5.82797e-06, Final residual = 1.35998e-07, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 7.50777e-07, Final residual = 3.27265e-08, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 2.83949e-06, Final residual = 6.4069e-08, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 4.13769e-07, Final residual = 1.63602e-08, No Iterations 2 PIMPLE: iteration 5 GAMG: Solving for p_rgh, Initial residual = 1.43059e-06, Final residual = 3.14307e-08, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 2.44785e-07, Final residual = 8.03719e-09, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 7.19056e-07, Final residual = 1.59301e-08, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 1.48655e-07, Final residual = 1.32698e-08, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 3.65799e-07, Final residual = 1.3061e-08, No Iterations 1 GAMGPCG: Solving for p_rgh, Initial residual = 9.6084e-08, Final residual = 9.6084e-08, No Iterations 0 DILUPBiCG: Solving for omega, Initial residual = 1.05021e-07, Final residual = 2.1834e-12, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 4.41147e-06, Final residual = 6.37142e-12, No Iterations 1 ExecutionTime = 59.58 s ClockTime = 60 s HTML Code:
plot "< cat log | grep 'Solving for alpha1' | cut -d' ' -f9 | tr -d ','" title 'alpha1' with lines,\ "< cat log | grep 'Solving for omega' | cut -d' ' -f9 | tr -d ','" title 'omega' with lines,\ "< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,\ "< cat log | grep 'Solving for Uk' | cut -d' ' -f9 | tr -d ','" title 'U' with lines,\ "< cat log | grep 'Solving for p_rgh' | cut -d' ' -f9 | tr -d ','" title 'p_rgh' with lines pause 1 reread Thanks in advance. |
June 9, 2014, 11:11 |
Mohammad Shakil Ahmmed
Rep Power: 15 |
In my cases, I prefer to use pyFoamPlotWatcher.py (which comes with pyFoam: http://openfoamwiki.net/index.php/Contrib/PyFoam). It's easy to use, and no need of any extra programming. cheers, #shakil |
June 10, 2014, 05:45 |
Baris (Heewa)
Rep Power: 13 |
Hi Shakil,
Thank you for your email. Actually, I already used pyFoamPlotWatcher.py. But as you can see in my one iteration, HTML Code:
smoothSolver: [B]Solving for Ux[/B], Initial residual = 0.001088847, Final residual = 8.176141e-05, No Iterations 6 smoothSolver: [B]Solving for Uy[/B], Initial residual = 0.003432152, Final residual = 0.0002506418, No Iterations 6 smoothSolver: [B]Solving for Uz[/B], Initial residual = 0.004479452, Final residual = 0.0003201872, No Iterations 6 GAMG: Solving for p, Initial residual = 0.02337899, Final residual = 0.0008043688, No Iterations 2 GAMG: Solving for p, Initial residual = 0.007815368, Final residual = 0.0005850772, No Iterations 1 GAMG: Solving for p, Initial residual = 0.001613976, Final residual = 0.0001103631, No Iterations 2 GAMG: Solving for p, Initial residual = 0.001157861, Final residual = 8.520689e-05, No Iterations 1 GAMG: Solving for p, Initial residual = 0.0002718626, Final residual = 2.288669e-05, No Iterations 2 time step continuity errors : sum local = 1.079882e-05, global = 3.552218e-08, cumulative = 0.002264786 smoothSolver: Solving for epsilon, Initial residual = 0.0006579817, Final residual = 5.450659e-05, No Thank you |
June 14, 2014, 10:04 |
#4 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Baris: The first problem here is that your initial description is seriously misleading The problem isn't a plotting issue, the problem is that the residuals for the velocity simply don't exist in the log file. The first approach on this is to search (instead of asking ) on the forum if someone else has seen this issue in the past. Let's see... I searched for: Code:
interPhaseChangeFoam velocity residuals And the answer is right there on the second post: Quote:
Bruno |
June 15, 2014, 23:30 |
Baris (Heewa)
Rep Power: 13 |
Dear Bruno,
Thank you so much for your answer. Yeah you are right. sorry for my misleading.I should be more careful before asking. B. |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
