April 2, 2014, 10:33 |
Discontinuities in the probe signal
Rep Power: 13 |
Hello OpenFOAMers,
I run a simulation but it seemed to me that there was not enough samples so I run more time steps from the last saved time. However I have got a different signal, and confirmed by a the same simulation run form 0 to the new end time. I did not do reconstructPar because it was simply to run the same case in the same number of processors. However I have other cases where I did the reconstructPar and then the decomposePar -force and a shift is present. Does anyone know what this might be ? Thanks in advance I have attached some examples with the data from the probes. (Forgive me if I did not put the images in the usual way.) no_reconstruction_fewsamples.jpg no_reconstruction_more_samples.jpg reconstruction_shift_0.jpg reconstruction_shift_1.jpg reconstruction_shift_2.jpg
Se Urso Vires Foge Tocando Gaita Para Hamburgo |
April 4, 2014, 16:04 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi guilha,
There are several possibilities that come to mind, so to list just a few:
Best regards, Bruno
Free Surface Ship Flow | timfranke | OpenFOAM Running, Solving & CFD | 322 | March 3, 2021 09:04 |
Using Probe for part of a patch | ndr | OpenFOAM Running, Solving & CFD | 7 | April 4, 2019 06:26 |
Backtrace errors while running on a HPC with buoyantBoussinesqSimpleFoam | Thangam | OpenFOAM Running, Solving & CFD | 2 | July 11, 2014 23:39 |
How can I find the attenuation of the pressure signal | RKR | Main CFD Forum | 0 | February 23, 2011 07:06 |
Killed by signal 8 after first timestep | matthias | OpenFOAM Running, Solving & CFD | 0 | December 9, 2005 08:06 |
