Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Cell areas in a patch
Old   April 2, 2014, 09:59
Default Cell areas in a patch
Euan Foster
EFoster2 is on a distinguished road
Dear all,
I have a trapezoidal pipe network that I have completed a simulation for. I now need to find the area-weighted average of the wall shear stress of which I need to know the cell area.
Previously all my simulation have been with rectangular cross sections so I have been able to find out the cell area with ease by doing it manually.
I have come across this post about finding the cell areas:
http://www.cfd-online.com/Forums/ope...rea-patch.html
and that subsequently refers you to this post:
http://www.cfd-online.com/Forums/ope...tml#post297002
They suggest various lines of code to be implemented. But since I am a pretty new user of openFoam and linux in general, I am not too sure of how and where they are implementing this code? Does anyone have any suggestions?
Or an alternative technique?
EFoster2 is offline   Reply With Quote
Old   April 5, 2014, 10:59
Euan Foster
The answer
http://www.cfd-online.com/Forums/ope...nt-planes.html
Old   June 21, 2019, 15:51
Default quick regex solution
LeeRuns is on a distinguished road
TLDR:use this regex code, only tested in openfoam 4!
postProcess -func 'patchIntegrate(name=somePatchName,someFiledName)' | grep -Po "((?<=total area   =).*([0-9])*)"
Full Description:
By using the postProcess function utility we can check the value of a field such as U,p,k,nut, T over a whole patch. To be able to have the integrated value the computer must have an area. Luckily that area gets printed when we perform a funciton such as integrate velocity over a face. So then you can just use regex string to manipulate the return from openfoam. Notes that I am not a regex star, so i did an exact string which requires that there is a line with 'total area' followed by 3 spaces and then an equals sign. If someone else has a better solution then pls supply
1. GO TO THE CASE DIRECTORY
  1. change directory to case you want to analyze
  2. punch this in
    (must replace somePatchName, someFieldName
Here is an applied example in which the "inlet" patch is the one i want to find the area of and I use the U field to get it's area printed. This works because my simulation calculates the velocity. Whether the velocity is a set value or is varied by the solver is irrelevant.
postProcess -func 'patchIntegrate(name=inlet,U)' | grep -Po "((?<=total area   =).*([0-9])*)"
that will print the value to the terminal, in reality this will work with most programming languages bc they all support regex.
While the openfoam naitive compilation is a great solution. Here is a a
LeeRuns is offline   Reply With Quote
cell, cell area, patch
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 13:23
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
