March 24, 2014, 15:13 |
Recirculating region not shown
ArathoN
Rep Power: 16 |
Hi foamers,
I'm simulating the backward facing step and I'm facing a strange problem, if i plot the wallshearstress the variable varies its sign meaning there is a recirculating region but if I use the stream tracer option on paraFoam it shows me no recirculating region. I changed the BCs, schemes/fvsolution and mesh (I'm considering uniform mesh with various grid size from coarse to fine), but still the problem persist. Am I using the wrong option to see the stream lines and so the recirculating region? I didn't modify any option in the 'stream tracer' menu. Please can someone help me here, I don't know what to do anymore. If it is needed i'll post my dropbox link of teh folder case. |
March 24, 2014, 16:00 |
Niels Nielsen
Rep Power: 27 |
Hi
You just need to initialize the streamlines just after the backwards facing step. Think about it, for a particle of zero mass it will by virtually impossible to be "dragged" into the re-circulation zone as the velocity gradient is simply too steep. The particle will only "see" the upper part of the re-circulation zone if released at the inlet. At the re-circulation area it simply "glides" on top of it. So whenever looking at streamlines think of them as particles released into the flow. That also means that when you are looking for specific flow-patterns it is of great importance to release the streamlines at proper locations.
Linnemann PS. I do not do personal support, so please post in the forums. |
March 24, 2014, 16:25 |
#3 | |
ArathoN
Rep Power: 16 |
P.S Even though the recirculating region can be considered an 'isolated' region from the flow it should be the Entrainment, can paraFoam "trace" it? |
March 25, 2014, 13:13 |
ArathoN
Rep Power: 16 |
No one has an idea how to resolve this?
March 25, 2014, 13:39 |
ArathoN
Rep Power: 16 |
Ok problem solved, the problem was in the settings of the streamtracer in fact if i plot the velocity vectors using cellcenters/glyph I can see the recirculating region. In particular the problem was the seed line, in fact I have to consider a line parallel to the section of the channel after the step otherwise it will not plot the recirculatin region.
Do any of you know why? And how can i specify the other options with regard of my geometry? |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
