February 14, 2014, 11:38 |
visualize OF using Matlab
Rep Power: 12 |
hi there,
I got the openfoam results of the three dimensional fields. Now I would like to make a planar slice of it and then visualize the 2D slice using matlab. Does anybody know how to realize it? I know matlab may only handle the slice data of structured meshes, however in openfoam as you know the meshes are unstructured. Anybody know how to do it properly? Thank you all. flames |
February 14, 2014, 13:21 |
Anton Kidess
Rep Power: 30 |
Use the "sample" tool to get data on a slice (in ASCII format). If you have problems plotting that data in MATLAB directly, you can interpolate it to a structured grid using builtin MATLAB functions.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
February 14, 2014, 17:02 |
Rep Power: 12 |
Thank you! If I generate the structured mesh for openfoam, I found that I have to output the mesh as an unstructured mesh. So when I output the 'structured mesh', actually the results are still UNSTRUCTURED. I found that this is a little complex. Thanks.
How to start Fluent with Matlab?? | Jay Hu | FLUENT | 8 | November 9, 2022 06:30 |
Export/Import data contour plots with Matlab | meangreen | FLUENT | 11 | October 28, 2020 10:06 |
Linking with Matlab?? | LostinSpace | Phoenics | 0 | March 25, 2013 05:39 |
Live connection Matlab VS OF | levka | OpenFOAM Running, Solving & CFD | 0 | July 10, 2012 04:15 |
caling matlab in Fortran | HaKu | Main CFD Forum | 0 | July 16, 2009 15:35 |
