Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to visualize turbulence Eddy Viscosity?
Old   September 4, 2013, 01:23
Cool How to visualize turbulence Eddy Viscosity?
Tom
RTom is on a distinguished road
I am using OpenFOAM rhoPimpleFoam solver. I would like to know how to visualize the turbulence eddy viscosity of the model in paraview.
Should I run the simulation again? .
RTom is offline   Reply With Quote
Old   September 4, 2013, 15:21
Pete Bachant
pbachant is on a distinguished road
You can select the "nut" volume field in ParaView's object inspector then display this as a surface.
pbachant is offline   Reply With Quote
Old   September 4, 2013, 16:30
Tom
I can't select the "nut" volume field because I don not have the option as you can see in the attach file
Old   September 4, 2013, 16:39
Pete Bachant
Are you doing an RAS? The cavity tutorial for rhoPimpleFoam has a "mut" field but is not visible from that menu by default. You need to enable it in the Object Inspector menu on the left and click "apply".
Old   September 4, 2013, 17:14
Tom
You are right!
But I'm using Discretizer, so maybe is Discretizer who does not let me select any property.
eddy viscosity, openfoam 1.5-dev, post-processing, rhopimplefoam
Turbulence and viscosity of non-Newtonian Fluids David FLUENT 9 October 30, 2023 05:55
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 08:45
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Turbulence eddy frequency Michael CFX 1 December 23, 2008 17:24
