June 22, 2013, 20:29 |
wallHeatFlux and radiation
Craig Tickle
Rep Power: 13 |
Does the wallHeatFlux utility include radiation?.
I've been looking at a heated body in a still room (basically a modification of the hotRadiationRoom tutorial) using both the buoyantSimpleFoam and buoyantSimpleradiationFoam solvers. The total heat transfer from the body, as reported by wallHeatFlux is very similar for both solvers. However my back of the envelope calculations suggest there should be about 50%-75% difference for my case. If the wallHeatFlux utility doesn't include radiation, is there a simple way of extracting the total heat transfer due to radiation for a given surface? |
June 23, 2013, 06:55 |
Rep Power: 14 |
The default version did not calculate radiation. Search the form to find a fixed version.
June 27, 2013, 23:15 |
Craig Tickle
Rep Power: 13 |
Thank you - but do you have a link to the fixed version?. I've searched through the forum but can't seem to find anything relevant.
March 29, 2015, 11:14 |
mahtab
Rep Power: 12 |
Hi Foarmers,
I have the same problem.Is there the wallHeatFlux utility that include radiation heat flux?( I use buoyantBuossinesqSimpleFoam solver with radiation) best regards |
April 17, 2017, 10:00 |
Yuehan
Rep Power: 14 |
I made a version of wallHeatFlux utility for OF2.3, which accounts for radiative heat flux, following https://github.com/OpenFOAM/OpenFOAM...eatFlux.C#L117 Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011-2013 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application wallHeatFlux Description Calculates and writes the heat flux for all patches as the boundary field of a volScalarField and also prints the integrated flux for all wall patches. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "turbulenceModel.H" #include "solidThermo.H" #include "wallFvPatch.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { timeSelector::addOptions(); #include "addRegionOption.H" #include "setRootCase.H" #include "createTime.H" instantList timeDirs = timeSelector::select0(runTime, args); #include "createNamedMesh.H" forAll(timeDirs, timeI) { runTime.setTime(timeDirs[timeI], timeI); Info<< "Time = " << runTime.timeName() << endl; mesh.readUpdate(); #include "createFields.H" surfaceScalarField heatFlux ( fvc::interpolate ( ( turbulence.valid() ? turbulence->alphaEff()() : thermo->alpha() ) )*fvc::snGrad(h) ); // Read radiative heat-flux if available volScalarField Qr ( IOobject ( "Qr", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::NO_WRITE ), mesh, dimensionedScalar("Qr", dimMass/pow3(dimTime), 0.0) ); const surfaceScalarField::GeometricBoundaryField& patchHeatFlux = heatFlux.boundaryField(); const volScalarField::GeometricBoundaryField& patchRadHeatFlux = Qr.boundaryField(); const surfaceScalarField::GeometricBoundaryField& magSf = mesh.magSf().boundaryField(); Info<< "\nWall heat fluxes [W]" << endl; forAll(patchHeatFlux, patchi) { if (isA<wallFvPatch>(mesh.boundary()[patchi])) { scalar convFlux = gSum(magSf[patchi]*patchHeatFlux[patchi]); scalar radFlux = -gSum(magSf[patchi]*patchRadHeatFlux[patchi]); // Be careful of the sign Info<< mesh.boundary()[patchi].name() << endl << " convective: " << convFlux << endl << " radiative: " << radFlux << endl << " total: " << convFlux + radFlux << endl; } } Info<< endl; volScalarField wallHeatFlux ( IOobject ( "wallHeatFlux", runTime.timeName(), mesh ), mesh, dimensionedScalar("wallHeatFlux", heatFlux.dimensions(), 0.0) ); forAll(wallHeatFlux.boundaryField(), patchi) { wallHeatFlux.boundaryField()[patchi] = patchHeatFlux[patchi]; } wallHeatFlux.write(); // Write the total heat-flux including the radiative contribution // if available if (Qr.headerOk()) { volScalarField totalWallHeatFlux ( IOobject ( "totalWallHeatFlux", runTime.timeName(), mesh ), mesh, dimensionedScalar("totalWallHeatFlux", heatFlux.dimensions(), 0.0) ); forAll(totalWallHeatFlux.boundaryField(), patchi) { totalWallHeatFlux.boundaryField()[patchi] = patchHeatFlux[patchi] - patchRadHeatFlux[patchi]; // Be careful of the sign } totalWallHeatFlux.write(); } } Info<< "End" << endl; return 0; } // ************************************************************************* // |
December 2, 2018, 09:00 |
Deep
Rep Power: 9 |
This is an old thread but I've a very relevant question and I'm hoping for an answer.
I see this in wallHeatFlux.: for OF v6 Code:
if (foundObject<volScalarField>("qr")) { const volScalarField& qr = lookupObject<volScalarField>("qr"); const volScalarField::Boundary& radHeatFluxBf = qr.boundaryField(); forAll(wallHeatFluxBf, patchi) { if (!wallHeatFluxBf[patchi].coupled()) { wallHeatFluxBf[patchi] -= radHeatFluxBf[patchi]; } } } return twallHeatFlux; } This when compared to older versions e.g. 2.3.x is nonexistent. This means older versions calculated purely convection heat flux at wall (basic Fourier equation with calculated k for fluid). So I'm wondering if there's a way to separate the two calculations. I want to know how much is convective heat flux and how much is the radiative heat flux along with the effective heat flux. How do I achieve this? One way would be to turn off radiation calculation by some means (how?) and rerun the case with on to find out the difference. This is not a good idea though; twice the time used. Any ideas? Need some clue. |
