Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
how to calculate mass flow rate on patches and summation of that during the run?
Like Tree23Likes
Old   February 2, 2017, 15:22
Philippose Rajan
philippose will become famous soon enough
Hello both of you,
@Bernhard: I think what Sridhar meant by "last step" is that he prepared his case, and setup everything, and as the "last step", started the simulation using the "mpirun ...." command, which then immediately caused the simulation to abort with the error he has shown.
Dont think he meant "last step" as in... last simulation iteration.
@ Bernhard, Sridhar:
I think the error can be found here...:
veloFlow
type swakExpression;
valueType internalField;
verbose true;
outputControl timeStep;
outputInterval 1;
aliases {alpha alpha.water;}
variables ("thres=0.60;")
expression "(alpha>thres) ? mag(U) : 0";
accumulations (max weightedAverage);
total
verbose true;
outputInterval 1;
expression "vol()*alpha";
accumulations (sum);
There are missing ";" (semi-colons) at the end of the lines "aliases" (in both veloFlow and total) and "variables" (in veloFlow).
This is triggering the error.
Regards,
Philippose
philippose is offline   Reply With Quote
Old   February 3, 2017, 00:36
shri@ is on a distinguished road
Hello !
@ philippose sir,
Yes the error was in the missing semicolon at the end. I made the changes and it worked.
Thank you very much for reply.
@ Bernhard sir,
Here's the sequence of operations
1. blockMesh >> works fine
2. checkMesh >> "Mesh OK"
3. setFields >> works fine
4. decomposePar >> works fine
5. mpirun -np 8 renumberMesh -overwrite -parallel >> works fine
6. mpirun -np 8 interFoam -parallel >> this prompts the error I quoted above.
As philippose sir suggested the error prompts even before the first timestep is calculated.
I am working with OpenFoam 3.0.x and swak version is 0.4.1 and ubuntu 15.10. (I am able to use other functionalities of swak4Foam with current setup)
Thank you
Shridhar
shri@ is offline   Reply With Quote
Old   February 16, 2021, 09:20
Andrea23 is on a distinguished road
Hi;
Maybe I am a bit late but I am trying to do something similar I want to calculate the output flow of a scalar, so I want to calculate phi*T (T is the volScalarField)
volFlow
valueType patch;
patchName OUTLET;
verbose true;
timeEnd 500;
outputInterval 5;
writeControl timeStep;
writeInterval 5;
expression "phi*T";
accumulation (sum);
I have swak4foam installed, I am using openFoam 8 and I loaded these libraries in controlDict
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libgroovyBC.so"
"fieldFunctionObjects.so"
"libgroovyBC.so"
But openfoam does not write the output of this function. Do you know the problem?
"phi*T" is correct? I want the sum for all boundary cell of "outflow facecell phi * cellcenter value of T"
last thing "accumulation (sum)" sum values of all previous timesteps (so in time 3 the value is time1+time2+time3)?
Andrea23 is offline   Reply With Quote
Old   February 16, 2021, 09:31
Default scalar flux only with OpenFOAM
  #104
Lourenço SM
lourencosm is on a distinguished road
Hey,
You don't need swak4Foam for this anymore:
fluxT
    type            surfaceFieldValue;
    libs            ("libfieldFunctionObjects.so");
    writeInterval     1;
    writeFields        false;
    writeArea	   false;
    log                   false;
    surfaceFormat   none;
    regionType      patch;
    name             OUTLET;
    operation       weightedSum;
    weightField     T;
    fields             (phi);
    scaleFactor     -1;
Originally Posted by Andrea23 View Post
Hi;
volFlow
valueType patch;
patchName OUTLET;
verbose true;
timeEnd 500;
outputInterval 5;
writeInterval 5;
expression "phi*T";
accumulation (sum);
libs (
"libOpenFOAM.so"
"libgroovyBC.so"
"libgroovyBC.so"
Andrea23 likes this.
lourencosm is offline   Reply With Quote
Old   February 16, 2021, 09:46
Originally Posted by lourencosm View Post
Hey,
fluxT
    writeInterval     1;
    writeFields        false;
    writeArea	   false;
    log                   false;
    surfaceFormat   none;
    regionType      patch;
    name             OUTLET;
    weightField     T;
    fields             (phi);
    scaleFactor     -1;
Thanks a lot, it works
lourencosm likes this.
