Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
how can see Cp values?
Like Tree16Likes
Old   November 18, 2015, 19:34
ait
Aly Taleb
ait is on a distinguished road
Hi everybody,
What does one need to do if one wants the solver to update a temperature dependent Cp for every time step? I am running coldEngineFoam and it only calculates Cp through Janaf for the beginning of the run. After that Cp is constant although the temperature fluctuates. All the solutions are post processing. Cp is calculated at the end of the run depending on the temperature field. I want the temperature field to be coupled to the varying Cp.
Thanks!
ait is offline   Reply With Quote
Old   November 19, 2015, 04:34
Agustín Villa
agustinvo is on a distinguished road
Originally Posted by taleb.aly@gmail.com View Post
Hi everybody,
Thanks!
taking a look to the code, you are using the energy equation of rhoSimpleFoam. Inside that file, you have thermo.correct(), which is updating Cp each time step.
This is the thing you were asking for? Because it should change once your equation is solved.
agustinvo is offline   Reply With Quote
Old   November 19, 2015, 16:20
ait
Aly Taleb
Thanks agustinvo. You are right. It does calculate an updated Cp value for every time step. For some reason, the output that I wrote for Cp only showed the value calculated at the beginning of the run and did not change it for the time steps.
I wrote the following in the createFields.H file:
   volScalarField heatCp
	IOobject
		"heatCp",
		runTime.timeName(),
		mesh,
		IOobject::NO_READ,
                IOobject::AUTO_WRITE
    thermo.Cp()
I also added the the following in the controlDict file:
heatCp
        type            cellSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
	outputControl   timeStep;
        outputInterval  1;
        log             true;
        valueOutput     false;
        source          all;
        sourceName      none;
        operation       volAverage;
        fields
		heatCp
Additionally, if I write "Cp" instead of "heatCp" in the createFields.H file, it gives me an error while compiling. Can somebody help me produce the correct output?
Kummi likes this.
Old   November 24, 2015, 11:30
Agustín Villa
Did you try to write in your code, just after the thermo.correct()
heatCp=thermo.Cp
this should update your variable each time step
Old   November 26, 2015, 07:59
ait
Aly Taleb
Thanks augustinvo. I've found a work-around for the problem. I tried your suggestion but it gives me an error. However, I don't need this solution any more
Old   March 10, 2016, 10:56
Gerrit is on a distinguished road
sorry to bump into this thread again. I would like to see the cp values after my simulation. I used wyldckats last code, but when I try to wmake it I gain this:
Making dependency list for source file specificHeat.C
could not open file cyclicAMILduInterface.H for source file specificHeat.C due to No such file or directory
could not open file cyclicAMIPolyPatch.H for source file specificHeat.C due to No such file or directory
SOURCE=specificHeat.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/opt/openfoam240/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam240/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam240/src/OpenFOAM/lnInclude -I/opt/openfoam240/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/specificHeat.o
In file included from /opt/openfoam240/src/finiteVolume/lnInclude/ddtScheme.C:30:0,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/ddtScheme.H:325,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvcDdt.H:199,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvc.H:44,
                 from /opt/openfoam240/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from specificHeat.C:27:
/opt/openfoam240/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:35: fatal error: cyclicAMILduInterface.H: No such file or directory
 #include "cyclicAMILduInterface.H"
compilation terminated.
make: *** [Make/linux64GccDPOpt/specificHeat.o] Error 1
I know that this is due to the fact, that I use OF 2.4.0, but I would like to solve this. Could someone help? I tried to find where the software uses cyclicAMILduInterface.H, but could not find it...
If it is looking for it, but does not find it, is there maybe only a new place or name of cyclicAMILduInterface.H?
Thank you.
Best
Gerrit is offline   Reply With Quote
Old   March 11, 2016, 10:56
Freedom
wenxu is on a distinguished road
Dear Georg,
What's wrong with the "Not implemented" problem as you posted? Could you tell us how to solve this problem?
Best,
Xu
wenxu is offline   Reply With Quote
Old   March 13, 2016, 12:48
Retired Super Moderator
Bruno Santos
Quick answers/questions:
@Gerrit:
Simply stating "last code" is a bit ambiguous, because I or you might have missed which exact post was the last one with code
Anyway, see this post: http://www.cfd-online.com/Forums/ope...tml#post567796 - post #2
@wenxu:
Originally Posted by wenxu View Post
Dear Georg,
Georg did state how it was solved... at least it looks like it, as described in post #31.
Old   March 14, 2016, 04:34
Hi Bruno,
thank you very much for your reply! I refered to post #17,
but this part of your answer solved my problem already!
Best
wyldckat likes this.
Old   April 15, 2017, 17:19
Default read Cp value from thermodynamics dictionary
  #50
mom
mom is on a distinguished road
Dear Foamers, Using cHT solver, How can I get the Cp value from my thermophysicalProperties in constant/ into controlDict in system?
my thermophysicalProperties file looks like this:
mixture
thermodynamics
Hf 0;
Cp 12;
Is it possible to get it with a command like :
const volScalarField& T = mesh_.lookupObject<volScalarField>("T");
that is used for temperature?
Annoying is that I managed to access thermodynamics dictionary (dictionary that you can see above) but I don't know how to extract Cp value from it, is there any command that I can use for it?
Kummi likes this.
mom is offline   Reply With Quote
Old   July 11, 2019, 08:54
Default cp coeffs
  #51
TAKILT Hocine
kévine is on a distinguished road
hello all
can someone help me to see the cp of a fluid after the combustion air-H2 to be able to calculate gamma
mass fraction:
H2 = 1
H2O = 0.256
O2 = 0.258
N2 = 0.486
THANK YOU
kévine is offline   Reply With Quote
Old   June 18, 2021, 08:19
Default Cp field for multiphase solvers
  #52
john myce is on a distinguished road
Hi all !
I am trying to add the isobaric heat capacity in createFields.H to visualize it using the multiphase solver compressibleInterFoam.
So I added the following lines on the createFields.H file :
volScalarField Cp
	IOobject
		"Cp",
		runTime.timeName(),
		mesh,
		IOobject::READ_IF_PRESENT,
    mixture.thermo1().Cp()()*alpha1 + mixture.thermo2().Cp()()*alpha2
What it does : It actually reads the initial value but it does not update the value during the simulation (please refers to the image attached, comparing cp vs rho)
I tried to follow the method suggested by wyldckat & gork by adding these following lines :
autoPtr<rhoThermo> pThermo(rhoThermo::New(mesh));
rhoThermo& thermo = pThermo();
thermo.validate(args.executable(), "h", "e");
The recompilation works but when I run again the simulation, it stop with the following error (2nd image attached).
Actually, this message is normal as I declare the thermo package in separate thermophysicalProperties for each phase (for instance thermophysicalProperties.liquid and thermophysicalProperties.gas)
So my question is how can I do to update the Cp by forcing the code to read into the right thermophysicalProperties files ?
Cheers,
john myce is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Numerical errors in nested domain with pre-calculated boundary values Arnoldinho OpenFOAM Running, Solving & CFD 3 April 4, 2012 11:31
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 12:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 12:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
