Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
sampling when mesh has moving points
Old   March 4, 2013, 03:50
Default sampling when mesh has moving points
Pablo Higuera
Phicau is on a distinguished road
Dear all,
I am trying to sample along a line for a mesh where points move, hence, when the initial cells where the line is located move away I get an error and the sampling process is aborted:
Time = 0
Time = 0.05
Time = 0.1
Time = 0.15
--> FOAM FATAL ERROR:
None of the neighbours of face 887211 contains point (44.9001 0.000100006 1.105)
    From function sampledSet::getCell(const label, const point&)
    in file sampledSet/sampledSet/sampledSet.C at line 105.
FOAM aborting
Any clue on how to tell OpenFOAM to read the "points" file from the time folder instead from the polymesh one?
Just to clarify, I want to measure always at the same location, it does not matter at which cell.
Best,
Pablo
Phicau is offline   Reply With Quote
Old   March 4, 2013, 04:34
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Pablo,
What version are you using? I have had similar problems in the official release, but never in 1.6-ext. I never came across a solution, though.
Good luck,
Niels
ngj is offline   Reply With Quote
Old   March 4, 2013, 04:41
Pablo Higuera
Hi Niels,
we are currently using 2.1.1.
Good to know, I will then try to dig my way out of here programming...
Thanks!
Old   March 4, 2013, 11:42
HECKMANN Frédéric
fredo490 is on a distinguished road
Does this problem happen when only a part of your line I'd out of the domain or only when all the line gets out?
By the way, what can of deformation do you use? Translating?
fredo490 is offline   Reply With Quote
Old   March 4, 2013, 12:19
Pablo Higuera
actually my line is always within the domain. The problem arises when any location of the line starts to belong to other cell than the initial one.
I am using a modified version of dynamicMotionSolverFvMesh.
Best,
Pablo
Old   March 4, 2013, 12:24
HECKMANN Frédéric
Can you use a post treatment software like EnSight or ParaView? It would make the thing easier (but longer)
Old   March 4, 2013, 12:36
Pablo Higuera
Definitely.
There is another option which I currently use: sample for free surface as an isosurface, and then by using a python script I obtain the time series of free surface elevation anywhere. This is kind of brute force, though.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Question on moving mesh, mesh velocity is really small! ripperjack Main CFD Forum 2 April 28, 2014 14:37
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
