Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
runtime postprocessing, parallel case with cyclics
Old   January 8, 2013, 09:00
Default runtime postprocessing, parallel case with cyclics
David Wienecke
Kaffeeknecht is on a distinguished road
Hi!
I'd like to use the cuttingPlane FO at runtime on my parallel Case which has two cyclics.
Here is what happens:
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] Unhandled coupledPolyPatch type processorCyclic
[0]
[0]     From function isoSurface::collocatedFaces(const coupledPolyPatch&) const
[0]     in file sampledSurface/isoSurface/isoSurface.C at line 94.
[0]
FOAM parallel run aborting
I heard you can avoid this, when the decomposition doesn't cut the cyclics, but is there any other way to get it running?
Thanks,
David
Kaffeeknecht is offline   Reply With Quote
Old   April 20, 2016, 11:54
Hang Meng
windsimu is on a distinguished road
Send a message via Skype™ to windsimu
Hi, I would like to know that have you solved this prob. ?
windsimu is offline   Reply With Quote
Post processing a parallel case Gearb0x OpenFOAM Post-Processing 11 March 8, 2022 13:16
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM Bugs 17 April 29, 2013 00:44
Slow case loading on parallel fluent jhome Hardware 3 December 21, 2011 16:19
[OpenFOAM] Paraview in Prallel (server-client) prapanj ParaView 11 September 24, 2010 08:12
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
