Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
How to calculate torque from the simulation result
Like Tree16Likes
Old   December 11, 2019, 12:19
Jingna Pan
J. Pan is on a distinguished road
Originally Posted by sharonyue View Post
Update,
Oh, time flies...
I think I figure it out, put it simple, if we want calculate the torque on the blade, this is quite simple, please see the output below:
forces forces output:
    sum of forces:
        pressure : (70.3478 2.53417 -0.129928)
        viscous  : (-8.35929e-07 -3.77215e-07 -9.01343e-07)
        porous   : (0 0 0)
    sum of moments:
        pressure : (-0.01138 -0.00344619 -9.2415)
        viscous  : (-8.14101e-08 -1.81033e-08 7.56807e-08)
        porous   : (0 0 0)
U can neglect all the other things if u just need the value of torque. The value on the red is torque. From this torque we can use this to calculate power.
power = 2 * 3.14 * rps * torque
By this, I got almost the rite power with experiment.
Dear sharonyue,
I am confused that why your torque is minus. In my case (2D Savonius rotor), I got the moment value in every time step. And I calculated the average value of all output values of Z component, which is also a negative value. Can you help me to explain the reason of minus value please? I am stuck for a long time. My controlDict is shown as below:
functions
forces
type forces;
libs ("libforces.so");
writeControl timeStep;
writeInterval 1;
patches (dragblade_1 dragblade_2);
porosity no;
pRef 0;
rho rhoInf;
log true;
rhoInf 1.225;
CofR (0 0 0);
pitchAxis (0 0 -1);
Best, J.Pan
J. Pan is offline   Reply With Quote
Old   December 11, 2019, 12:24
Jingna Pan
Update,
Oh, time flies...
    sum of forces:
        porous   : (0 0 0)
    sum of moments:
        porous   : (0 0 0)
Dear sharon,
May I ask you to explain why the torque is minus please? I am confused about that.
Best, J.Pan
Torque of wind turbine simulation caohan FLUENT 8 August 12, 2014 00:01
Torque calculation of 2D VAWT Wind Turbine Anonymized_JL1 FLUENT 14 September 26, 2013 04:35
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 10:32
How calculate simulation duration - CFX Solver eRzBeNgEl CFX 3 January 24, 2011 17:35
about use macro to compute torque in TASCflow lancy CFX 0 June 10, 2003 07:19
