October 22, 2012, 19:19 |
Best free tool for post Processing
M Mallikarjuna Reddy
Rep Power: 14 |
Hi Foamers,
I am new to openFoam. I completed simulation part. Now i need to post process my results. Actually i am working with flow of fluid through channels. For the publication purpose i need to compare velocity profiles at different locations, with in one graph (And i need to normalize the fields too with max velocity). To do this is there any third party open tool is available or paraView is enough. Please give your valuable suggestions. Thanks Regards Mallikarjuna |
October 23, 2012, 03:42 |
Anton Kidess
Rep Power: 30 |
I like paraview, but I prefer gnuplot or qtiplot for 2D plots.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
October 23, 2012, 04:04 |
Rep Power: 14 |
Hi akidess,
Thanks for quick reply. I want to compare other results(another geometry results, analytical results & experimental results). For each and every position i want to rescale the space coordinates. Can i do these things in paraView? Thanks Regards Mallikarjuna |
October 23, 2012, 04:08 |
Anton Kidess
Rep Power: 30 |
I think that should work using the built-in calculator.
October 23, 2012, 04:11 |
Rep Power: 14 |
Hi Akidess,
Thanks for quick reply. I'll go through your suggestion. Is there any tutorial which explains in detail? Thanks Regards Mallikarjuna |
October 30, 2012, 13:57 |
Kevin Smith
Rep Power: 17 |
You could also just sample your fields in openfoam to generate csv files, and post process that data to your hearts content. Take a look at some of the function objects in openfoam.
Best free tool for Geometry creation | mmkr825 | OpenFOAM | 12 | October 8, 2012 03:53 |
New Free tool for Thermo-fluid analysis | Hamish | Main CFD Forum | 0 | November 8, 2011 14:47 |
Best post processing tool? | cheche | Main CFD Forum | 0 | January 27, 2011 12:02 |
Post Processing free surface flows | Chris Wetton | CFX | 2 | February 14, 2008 09:14 |
Free post processing | Ehsan | Main CFD Forum | 1 | January 10, 2008 09:59 |
