Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
WallShearStress for settlingFoam
Old   August 28, 2012, 05:25
Default [solved] WallShearStress for settlingFoam
Elise
Elise is on a distinguished road
I did a case with settlingFoam in a special geometry; water is flowing into a hemisphere as well as sand.
Now i would like to calculate the bed shear stress at this hemisphere, but the function wallshearstress only uses nu from the singlephase transport model.
What do I have to change in the file wallshearstress.C or createFields.H to obtain this wall shear stress in postprocessing mode?
I can also do the calculation myself with
tau = mu * dU/dy
Only how do I calculate this gradU normal to this hemisphere does wallgradU does this automatically or do I have to add a normal vector but how to do this?
Elise is offline   Reply With Quote
Old   August 28, 2012, 06:50
Elise
I changed the wallGradU.C file to
wallGradU.boundaryField()[patchi]= - U.boundaryField()[patchi].snGrad*patch().nf();
Is this the correct way to do this or does the wallgradU allready gives the values related to the wall instead of to the
defined axes?
Answere was in http://www.cfd-online.com/Forums/ope...tml#post186008
Problems with YPlusRAS and wallShearStress Peter85 OpenFOAM Post-Processing 21 May 4, 2016 06:15
problem with wallShearstress at interFaom jignesh_thaker2007 OpenFOAM 7 March 30, 2012 09:43
wallShearStress with compressible flow Ruehri OpenFOAM Post-Processing 0 June 11, 2010 05:14
linking wallshearstress values and faces prjohnston OpenFOAM Post-Processing 1 November 3, 2009 14:40
wallShearStress for compressible flow cbarry OpenFOAM 2 October 12, 2009 11:28
