To calculate wall shear stress in of210 for les simulation |
#41 | |
Zhiwei Zheng
Rep Power: 12 ![]() |
Have you solved these problems now? I need to do these now, help me. Thank you! |
#42 |
Rep Power: 13 ![]() |
You can use utilityFunctionObjects for this purpose. Google/grep it for usage guide. There you can adjust the output frequency as well.
I want to add that although judging by the magnitude of WSS might be a good way of judging about the statistical convergence of the simulation, I have found it only a necessary conditions, not sufficient. You have to compare probes' values of higher order statistics, time-averaged profiles, etc. |
#43 | |
Zhiwei Zheng
Thank you very much for your advice, I will try. In fact, I want to show the skin friction coefficient distribution around the cylinder, however the flow around the cylinder is unsteady, so I need to show the time-averaged profiles. |
#44 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
I've had this post of yours on my to-do list and only now was I able to look into this. I have to say that I was not able to make heads or tails from the data you've provided ![]() Anyway, from what I've seen in later posts of yours, it seems that you've solved the problem, as indicated here: http://www.cfd-online.com/Forums/ope...tml#post516964 post #21 Which means that there isn't much I can do here... oh well... Best regards, Bruno
#45 | |
Guilherme
Rep Power: 10 ![]() |
Thanks |
Measuring wall shear stress in bend pipe | liguifan | OpenFOAM | 70 | December 9, 2015 03:49 |
What is wall shear stress and shear strain rate? | warlocklw | Main CFD Forum | 2 | May 21, 2012 06:16 |
wall shear stress | lingo | FLUENT | 2 | June 2, 2003 03:40 |
Specifying shear stress on wall in 5.5.1 | michael rasmussen | CFX | 1 | May 19, 2003 09:49 |
plotting wall shear stress | Ellen | FLUENT | 1 | April 5, 2002 22:50 |
