Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
yPlusRAS and GGI
Old   May 25, 2012, 05:53
Default yPlusRAS and GGI
flowris is on a distinguished road
I am trying to calculate the y+ values after a RANS simulation involving GGI (Generalized Grid Interface). The command is simply
yPlusRAS
I have the impression that this command does not work when a GGI is present. Even the y values are not calculated correctly. Inside the sliding interface, y is almost zero, while outside of it, it is extremely large. Any suggestions to work around this problem?
flowris is offline   Reply With Quote
ggi, yplusras
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
