wallHeatFlux utility for an incompressible case |
August 21, 2018, 08:25 |
#61 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Nestor: My apologies for not getting back to you sooner on your post, but these past few years have been hectic on my side... Either way, I've did feel the need myself to update this utility to OpenFOAM 5, so I've now published the updated code for OpenFOAM 5 and 6, provided here: https://github.com/wyldckat/wallHeatFluxIncompressible Best regards, Bruno
November 30, 2018, 05:38 |
#62 | |
priyesh kakka
Rep Power: 8 |
December 22, 2018, 12:07 |
#63 |
Bruno Santos
Rep Power: 128 |
Quick answer: See this thread: Time-average of a patch (wallHeatFlux)
April 2, 2023, 08:46 |
installation problem on openfoam 2212
#64 |
Rep Power: 3 |
hello,
i m a new user of openfoam, and i have some problem to compill the wallheatfluxincompressible function. i work currently on openfoam2212. on the git, i only see instruction for openfoam 2, 5 and 6. Some one know if i can use this function on a openfoam.com version, not .org.. regards |
April 3, 2023, 15:35 |
#65 |
Thiago Parente Lima
Rep Power: 15 |
This is an old thread when OF had the solver buoyantBoussinesqSimpleFoam. The function wallHeatFlux didn't work on it. In OF 10 we have only the buoyantFoam solver and the function wallheatfluxincompressible is not necessary anymore, just use wallHeatFlux. The heat transfer solvers in OF changed a lot since 2015. It is better to keep up to date. Regards.
Fields of interest: buoyantFoam, chtMultRegionFoam. |
April 3, 2023, 15:53 |
#66 |
Rep Power: 3 |
thank you for your answer.
So you really think i can use wall heat flux in a compressible case ? because i tried once and i had some error about using the wrong solver.. i will send the message i had in this case, may be i have configurate wrong my simulation.. regards |
April 4, 2023, 10:54 |
#67 |
Thiago Parente Lima
Rep Power: 15 |
Yes, you can find good tutorials here: https://upcommons.upc.edu/bitstream/...REPORT_260.pdf
You may have to adapt something to run in OpenFoam 10, but they help a lot.
April 6, 2023, 04:25 |
#68 |
Rep Power: 3 |
Ok, i found a solution
thank you regards |
incompressible, open foam, wallheatflux |
how to create an internal fan for a multiRegion case? | phsieh2005 | OpenFOAM | 0 | February 2, 2012 17:32 |
wallHeatFlux utility in OpenFoam1.6 | maruthamuthu_venkatraman | OpenFOAM | 29 | October 3, 2011 11:43 |
thermal analysis - how to model internal fan? | Pei-Ying Hsieh | Main CFD Forum | 6 | March 20, 2008 11:35 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 18:49 |
