Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Problem in sampling data
Old   April 30, 2012, 14:04
Question Problem in sampling data
Mohammad Fereshtehpour
MOHAMMAD67 is on a distinguished road
Send a message via Skype™ to MOHAMMAD67
Dear Foamers
HI
I simulated a multiphase flow. After simulation completed I sampled data for drawing velocity profile. Unfortunately the sampled data are very different from what I saw in paraview.
Is there anyone know what happened to sampling?
Here you can see their comparison:
MOHAMMAD67 is offline   Reply With Quote
Old   April 30, 2012, 14:50
Alberto Passalacqua
How do you define the paraview line and the sampling line for the sample utility?
Best,
Alberto Passalacqua
Old   April 30, 2012, 15:03
Default Line Defining
Dear ALberto
I defined a line in paraview (start and end point) and then copy them to sample dict.
Old   April 30, 2012, 15:18
Alberto Passalacqua
You will obtain the same result with sample, if you set
interpolationScheme pointMVC;
Best,
Alberto Passalacqua
Old   May 1, 2012, 03:16
Default Problem solved!
Dear Alberto
thanks for your help. My problem was solved by your point.
the correct answer is attached here.
OpenFoam to Fluent data conversion Problem vemps OpenFOAM 1 August 8, 2011 03:30
"Data sampling for Time Statistics" Madhukar Rapaka FLUENT 2 June 20, 2011 12:28
Volume Fraction, profile data problem cfxmar CFX 5 August 19, 2009 09:09
Problem with export data from prostar Shanta Siemens 1 November 28, 2004 00:48
Problem in Track Data selen Siemens 2 August 7, 2003 14:06
