[OpenFOAM] How to smooth the visualization in a ParaFoamParaview |
July 18, 2005, 16:21 |
diablo80@web.de
Rep Power: 17 |
Dear All,
I would like to smooth the graphics, like if I did not have discrete data, but splines. Mostly when I am ploting iso contourns... Question: is that possible in paraview/paraFoam? Thanks a lot |
July 18, 2005, 18:48 |
Does adding normals help (Filt
Mattijs Janssens
Rep Power: 26 |
Does adding normals help (Filter->Normals)?
July 18, 2005, 19:44 |
Thanks, It helped, but did not
diablo80@web.de
Rep Power: 17 |
Thanks, It helped, but did not solved...
What I really would like to accomplish is producing good graphics (beautiful shadings etc...) even in a very coarse mesh... I am still seeing piecewise linear objects, instead of a nice smoothly-shaded 3D contour... I would love to see something really like a spline interpolation, so that even in coarse meshes the graphics would be fine... Thanks again, luiz |
March 1, 2008, 08:22 |
hi luiz,
did you manage to
Laurence Griffiths
Rep Power: 17 |
hi luiz,
did you manage to accomplish the smoothing? i'm now finding myself in the same situation. cheers, Laurence |
August 2, 2010, 04:39 |
Claus Meister
Rep Power: 18 |
I have just been in the same situation and I found a solution. During the starting of paraFoam such a case.OpenFOAM file is created and loaded. Now, in paraFoam open the file again, so that you have two sessions of it. One session should be the normal one and in the second session should only be used the patches which are intetended to be smooth by Filter->Alphabetical->Smooth.
Hopfully it will help; I wrote that fast here; ain't got no time. |
August 3, 2011, 06:52 |
Rep Power: 15 |
I´m interested in smoothing my geometry, as well.
Unfortunately in my case, the smooth filter is set in grey. Any Idea? Cheers, DITO |
August 3, 2011, 06:57 |
Claus Meister
Rep Power: 18 |
Choose another color! ;-)
August 3, 2011, 07:37 |
Rep Power: 15 |
the Filter is greyed out!
nice joke! |
November 23, 2012, 10:03 |
#9 |
Rep Power: 16 |
This is what worked in my case:
Filters: 1. Extract Surface 2. Generate Surface Normals (-> delivers smooth output) Regards, Christoph |
July 5, 2018, 17:08 |
Point Data
#10 |
Cole
Rep Power: 8 |
Use Point Data. If all you have is cell data you can convert to point data through the "cell data to point data" filter. Paraview automatically interpolates point data to complete the rendering. To complete the rendering for cell data paraview simply fills the cell volumes with it's associated data value.
HexaLab a new online tool for visualization and evaluation of hexahedral mesh | cignoni | Main CFD Forum | 1 | June 28, 2018 06:33 |
[General] Animating smooth transitions between views | kmatusik | ParaView | 0 | February 4, 2016 14:45 |
[OpenFOAM] Smooth visualization of a cut domain | KateEisenhower | ParaView | 1 | June 23, 2015 09:42 |
Using clip filter to acquire smooth interface | sharonyue | OpenFOAM Post-Processing | 0 | April 14, 2015 12:03 |
ICEM 10 smooth transition error | Stephen | CFX | 3 | March 13, 2007 10:23 |
