[OpenFOAM] QXcbConnection: Could not connect to display :0 |
January 5, 2018, 13:52 |
Georg
Rep Power: 8 |
until lunch i worked with openFoam and paraFoam and all of a sudden paraFoam won't start anymore. i already reinstalled docker-ce and openFoam, but the error remains. Here is the total message: bash-4.2# paraFoam Created temporary 'cavity.OpenFOAM' QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root' No protocol specified QXcbConnection: Could not connect to display :0 My System is Debian Stretch. OpenFoam and docker-se packages/binaries are installed according the guides on their webpages. I use them as root. As i did not change anything on the system, i have no clue where to start searching to solve the issue. The search results here and with google did not help so far. Could someone help me out please? Thanks in advance George |
May 11, 2018, 10:35 |
paraFoam not working!!!
Rep Power: 14 |
Hi everyone
I have installed the latest versions of OpenFoam and Paraview on my Mac system. I ran the cavity case and tried to view results via the command "paraFoam", but I got following messages from terminal: Created temporary 'cavity.OpenFOAM' QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-ofuser' QXcbConnection: Could not connect to display Can anyone help me sort out what the problem is? Thanks in advance |
May 11, 2018, 10:38 |
#3 | |
Rep Power: 14 |
Hi Schurl
I had the same problem, have you already sorted it out? Thanks in advance Quote:
July 14, 2018, 17:21 |
Kiran
Same problem here.
September 7, 2018, 06:29 |
Aucune sélection
I am new user of openFoam. I installed it this week, I have mac os X machine, and I get same error when typing paraFoam to post-process cavity exercise given tutorials, So I use : paraFoam -touch-all to create data files formats cavity.OpenFOAM, cavity.foam and cavity.blockMesh and then I copy cavity folder in my Documents directory as follows : cp -r cavity /home/ofuser/workingDir/Documents Then, I open Paraview and select cavity.OpenFOAM file in Documents directory to display it and it works all right |
December 8, 2018, 00:17 |
Error same as you
Rep Power: 7 |
Error same as you Code:
[ofuser@99e05d27cec3 cavity]$ Created temporary 'cavity.OpenFOAM' QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-ofuser' QXcbConnection: Could not connect to display All the best, Frank [Moderator note: this post was moved to here from another thread and was referring to what now is post #2 on this thread.] Last edited by wyldckat; March 6, 2019 at 19:38. Reason: see "Moderator note:" |
March 6, 2019, 14:30 |
#7 | |
Panos Koniavitis
Rep Power: 8 |
March 11, 2019, 06:19 |
Aucune sélection
[OpenFOAM] OpenFoam V6 via Docker: "Could not connect to any X display" | Boomessh | ParaView | 10 | April 30, 2021 11:42 |
error: connect failed | destroy | FLUENT | 7 | March 18, 2018 14:59 |
Scheme Executable Terminating Prematurely | ec44 | Fluent UDF and Scheme Programming | 1 | April 6, 2015 03:34 |
[OpenFOAM] Xlib: extension "GLX" missing on display | goldbeard | ParaView | 5 | March 24, 2013 13:12 |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 07:43 |
