Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] How to correctly show the result of #codeStream# internalField?
Like Tree19Likes
Old   May 7, 2017, 07:38
Exclamation How to correctly show the result of #codeStream# internalField?
Di Cheng
chengdi is on a distinguished road
Hi, everyone
I just used codeStream to generate some initial condtion and codedFixedValue to generate some boundary condtion. The codedFixedValue BC can be correctly executed and loaded using paraFoam (I am using OF1612+ in docker), however, the codeStream initial condition can be correctly interpreted and executed but cannot be loaded in paraFoam.
I was running the forwardStep with following "0/U" file
|  \\    /   O peration     | Version:  plus                                  |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
//internalField   uniform (3 0 0);
internalField  #codeStream
    code
        const IOdictionary& d = static_cast<const IOdictionary&>(dict);
        const fvMesh& mesh = refCast<const fvMesh>(d.db());
        vectorField T(mesh.nCells());
        const vectorField& CC = mesh.C(); //cell center
        forAll(CC,cellI)
            //spatial coordinates, type: scalar
        	scalar x = CC[cellI].x();
        	scalar y = CC[cellI].y();
        	scalar z = CC[cellI].z();
        	T[cellI] = vector(3+0.2*sin(10*x),0,0);
        //void Foam::Field<Type>::writeEntry(const word& keyword, Ostream& os) const
        T.writeEntry("", os);
    //! Optional:
    codeInclude
        #include "fvCFD.H"
    //! Optional:
    codeOptions
        -I$(LIB_SRC)/finiteVolume/lnInclude \
        -I$(LIB_SRC)/meshTools/lnInclude
    //! libs:
    codeLibs
        -lmeshTools
boundaryField
    inlet
        type            codedMixed;
        refValue        uniform (3 0 0); //default value
        refGradient     uniform (0 0 0); //default value
	valueFraction   uniform 1;
        redirectType    linearOscillatingBC; //name of new BC type
        code
        const vectorField& Cf = patch().Cf(); // get face center coordinate;
        scalar ymax = max(Cf&vector(0,1,0)); // `&` is dot product
        scalar ymin = min(Cf&vector(0,1,0));
        // Info<<"ymax="<<ymax<<",ymin="<<ymin<<nl;
        vectorField& rvf = this->refValue();
        vectorField& rgf = this->refGrad();
        scalarField& vf = this->valueFraction();
        //temporal coordinate, type: scalar
        scalar t =this->db().time().value(); // get time
        //Oscillating parameters
        scalar omega = 5;
        scalar A = 0.2;
        scalar tt = (1+A*sin(omega*t)); // temporal term, separated
        forAll(Cf,faceI)
        	//scalar x = Cf[faceI].x();
        	scalar y = Cf[faceI].y();
        	//scalar z = Cf[faceI].z();
        	rvf[faceI] = vector(((y-ymin)/(ymax-ymin)+2.5)*tt,0.0,0.0);
        	rgf[faceI] = Zero;
        	vf[faceI] = 1.0;
        //I do not know why I need to add those things
        //codeInclude
        //    #include "fvCFD.H"
        //codeOptions
        //    -I$(LIB_SRC)/finiteVolume/lnInclude
    outlet
        type            inletOutlet;
        inletValue      uniform (3 0 0);
        value           uniform (3 0 0);
    bottom
        type            symmetryPlane;
    top
        type            symmetryPlane;
    obstacle
        type            slip;
    defaultFaces
        type            empty;
And here is the output of crashing paraFoam when I try to load the data.
Created temporary 'forwardStepMod3.OpenFOAM'
Using #codeStream at line 21 in file "/home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/0/U"
Using #codeStream with "/home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ba5ce8457724532859ca03bd0612f92a5665a90f.so"
Invoking wmake libso /home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/dynamicCode/_ba5ce8457724532859ca03bd0612f92a5665a90f
--> FOAM FATAL IO ERROR:
Failed loading library "/home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ba5ce8457724532859ca03bd0612f92a5665a90f.so"
Did you add all libraries to the 'libs' entry in system/controlDict?
file: /home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/0/U from line 17 to line 17.
    From function static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
    in file db/dictionary/functionEntries/codeStream/codeStream.C at line 309.
FOAM exiting
I also tried to add "/home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ba5ce8457724532859ca03bd0612f92a5665 a90f.so" to my system/controlDict 's libs entry. Here is the output:
--> FOAM Warning :
    From function void* Foam::dlOpen(const Foam::fileName&, bool)
    in file POSIX.C at line 1244
    dlopen error : /home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ba5ce8457724532859ca03bd0612f92a5665a90f.so: undefined symbol: _ZTIN4Foam6fvMeshE
--> FOAM Warning :
    From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 101
    could not load "/home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_ba5ce8457724532859ca03bd0612f92a5665a90f.so"
FOAM exiting
I thought "_ZTIN4Foam6fvMeshE" must be something important. However, there is only one result from Google and I cannot see any related information in it.
tariq, tonnykz and Rodolfo Puraca like this.
chengdi is offline   Reply With Quote
Old   May 7, 2017, 09:34
Retired Super Moderator
Bruno Santos
Quick answer: You have this:
    codeOptions
    //! libs:
    codeLibs
        -lmeshTools
Notice that in the first block here you mention "finiteVolume", but in the "codeLibs" block you don't mention it. This isn't a problem when using the solver, because the solver already has this library loaded in. Therefore, you need to update the second block to this:
    //! libs:
    codeLibs
        -lmeshTools \
        -lfiniteVolume
tariq and anon_q like this.
Old   May 8, 2017, 03:08
Di Cheng
Dear Bruno
Thank you so much for you reply!
Old   May 8, 2017, 03:18
Di Cheng
Hi Bruno,
I just tried to use "paraview" rather than "paraFoam" to post-process the result after time "0".
However, the "U" field cannot be read and here is the errors:
ERROR: In /home/buzz2/pawan/OpenFOAM/ThirdParty-1606_plus/ParaView-5.0.1/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6497
vtkOpenFOAMReaderPrivate (0x40ace10): Error reading line 16332 of /home/di/OpenFOAM/di-v1612+/run/forwardStepMod3/8/U: Unsupported directive {
And here is content in "8/U"
internalField   nonuniform List<vector>
16128
(2.877288422651 -3.144469067245e-05 0)
        name            linearOscillatingBC;
        code            #{
        scalar omega = 5;
        scalar A = 0.2;
        forAll(Cf,faceI)
                rgf[faceI] = Zero;
                vf[faceI] = 1.0;
    outlet
Is there any way to solve this problem?
Last edited by wyldckat; May 8, 2017 at 20:17. Reason: Added [CODE][/CODE] markers
Old   May 8, 2017, 05:44
Antimony is on a distinguished road
AFAIK, there isn't a very straightforward way to do this.
What I do is to open up the result file and modify the type from 'coded...' to 'fixedValue'. OF seems to write the values in any case (usually in the line/lines right below type) and so making this change allows Paraview to understand and display the velocity.
Hope this helps.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   May 8, 2017, 20:19
Bruno Santos
Quick answer: If the file extension ".OpenFOAM" is not used and instead the built-in reader with ".foam" is used instead, then it will not work. You could try with ParaView 5.3, but I haven't tested it yet.
The only other solution is to use foamToVTK and then open the VTK files in ParaView.
tariq and virengos like this.
Old   May 9, 2017, 03:51
Di Cheng
Dear Bruno
Thanks for your suggestion. I will try foamToVTK.
Old   May 18, 2017, 16:58
Default Implementing a new IOobject
Tarang
gtarang is on a distinguished road
I am using OpenFOAM 4.1 for melting and solidification problem. I am following this thread Marangoni bc for writing marangoni BC. The boundary condition uses an IOobject of volVectorField gradT. The thread suggest putting IOobject in solver. I want to know the possibility of calculating gradT from controlDict using functionObjects or codeStream.
I have written the controlDict in this way
|  \\    /   O peration     | Version:  4.1                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     buoyantPimpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         30.0;
deltaT          1.0;
writeControl    adjustableRunTime;
writeInterval   10;
purgeWrite      0;
writeFormat     ascii;
writePrecision  8;
writeCompression off;
timeFormat      general;
timePrecision   10;
runTimeModifiable yes;
adjustTimeStep  yes;
libs
    "libmyBoundaryConditions.so"
    "libOpenFOAM.so"
maxCo           0.25;
maxDeltaT       1;
maxAlphaCo      1;
    #codeStream
        code
                IOobject
                    "gradT",
                    runTime.timeName(),
                    mesh,
                    IOobject::READ_IF_PRESENT,
                    IOobject::AUTO_WRITE
                fvc::grad(T)
        /*codeInclude
            #include "fvCFD.H"
        codeOptions
            -I$(LIB_SRC)/meshTools/lnInclude \
        codeLibs
            -lmeshTools
Kindly suggest me how can I calculate gradT.
Tarang
gtarang is offline   Reply With Quote
Old   May 20, 2017, 00:47
Di Cheng
I think you can use post-processor to calculate grad(T)
Old   May 20, 2017, 01:54
Tarang
Will I be able to use "post process"ed grad(T) as volVectorField in boundaryConditionFvPatchField?
Old   May 20, 2017, 23:38
Di Cheng
sorry, I misunderstood your purpose.
As far as I know. #codeStream is just used to generate some "TEXT" in the controlDict or other text-based configuration file for OpenFOAM. If you want to use some volVectorField grad(T) in your BC. you must modify your solver.
Old   May 21, 2017, 07:33
Tarang
Thanks chengdi. I have modified my solver to calculate gradT. One thing about the #codestream in controlDict I want to ask is that where in the execution flow process the code is executed?
Old   June 12, 2017, 11:34
Di Cheng
I think #codeStream is just used to generate texts.
You may understand it like this:
When the foam app read the controlDict, what your app actually read is the text generated by your #codeStream at the start of the dict-entry-reading.
Old   September 7, 2017, 11:08
Przemek
gaza is on a distinguished road
Hi
I use codeStream BC for U
I tried to access time as you posted in How to correctly show the result of #codeStream# internalField?
However I got error "error: invalid use of ‘this’ in non-member function"
in the line scalar t = this->db().time().value();
My U file is
internalField   uniform (16 0 0);
boundaryField
    WALL
        type            fixedValue;
        value            #codeStream
            codeInclude
                #include "fvCFD.H";
            codeOptions
            codeLibs
                -lmeshTools \
                -lfiniteVolume
            code
                    dict.parent().parent()
                const label id = mesh.boundary().findPatchID("WALL");
                const fvPatch& patch = mesh.boundary()[id];
                vectorField U(patch.size(), vector(0, 0, 0));
                forAll(U,i)
                    U[i] = vector(1, 0., 0.);
                U.writeEntry("", os);
Do you know what is wrong?
tonnykz, rarnaunot and sxpsxp007 like this.
best regards
pblasiak
gaza is offline   Reply With Quote
Old   July 4, 2018, 10:14
Rosario Arnau
rarnaunot is on a distinguished road
Hi Foamers,
I got the same error as you:
Originally Posted by gaza View Post
Hi
My U file is
How did you solve this error?
Thanks!
rarnaunot is offline   Reply With Quote
Old   July 5, 2018, 09:34
Przemek
Hi
I did not solve this. I used codedFixedValue instead of fixedValue.
rarnaunot likes this.
best regards
pblasiak
Old   July 5, 2018, 11:18
Rosario Arnau
I'm not really into the difference between codedFixedValue and fixedValue. But i am initializing a IC so I use: internalField #codeStream
Hi
Old   July 5, 2018, 14:04
Przemek
you can find basic info here
https://www.openfoam.com/documentati...xed-value.html
or search on the forum
best regards
pblasiak
Old   September 21, 2018, 09:41
Ali Amarloo
Ali Amarloo is on a distinguished road
Hi
My U file is
boundaryField
    WALL
        type            fixedValue;
        value            #codeStream
            codeInclude
                #include "fvCFD.H";
            codeOptions
            codeLibs
                -lmeshTools \
                -lfiniteVolume
            code
                forAll(U,i)
I have the same problem
It seems that by "scalar t = this->db().time().value(); " we can access time just for codedFixedvalue
Does anybody know how can I access time (of simulation) in "codeStream"?
kcavatar and kooki_13 like this.
Ali Amarloo is offline   Reply With Quote
Old   September 21, 2018, 15:25
Przemek
change
fixedValue
into
codedFixedValue
atulkjoy likes this.
best regards
pblasiak
codestream, openfoam, parafoam
Difference of the max function result with full field, internalField and boundaryFiel cyss38 OpenFOAM Programming & Development 1 October 2, 2018 06:39
CFD post cannot load results-Error appeared? mariam.sara ANSYS 9 September 17, 2018 16:23
[Workbench] Current result file may not contain requested result data zhizhuo ANSYS Meshing & Geometry 0 December 13, 2017 05:18
Simulation won't show turbulence pete_87 OpenFOAM Running, Solving & CFD 4 June 25, 2014 12:35
Geometry show in Result Display ShFlow FLOW-3D 3 January 11, 2009 21:51
