Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
swak4Foam - New release
Like Tree29Likes
Old   November 20, 2014, 15:23
Assistant Moderator
Bernhard Gschaider
Originally Posted by Masgar View Post
Hi Bernhard,
Thanks a lot for your quick response as always. I tried the 2.x-release downloaded from:
svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ swak4Foam_2.x
I attached the make log file output from this compile. Then I also tried this one which was suggested by Bruno (https://github.com/wyldckat/swak4foam/tree/OF22X), but I am not sure if this principally should work for me or not; anyway it did not
Thanks and Best,
Mahdi
Strange. Should compile with your OF-Version. Try putting a
#define FOAM_NEW_MESH2MESH 1
at the start of MeshInterpolationOrder.H
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 20, 2014, 16:03
Mahdi
Masgar is on a distinguished road
Hi Bernhard,
Thanks for your reply,
I put "#define FOAM_NEW_MESH2MESH 1" in the file you mentioned but there are still errors coming up. Is it possible that my OF is not installed accurately? The solvers I have tried are working, however. In case you see any point to re-install OF2.3, which source do you recommend to download and install it for Ubuntu 14.04?
Thanks and Best,
Mahdi
Masgar is offline   Reply With Quote
Troubles with heat release rate Xavier Ponticq CFX 4 September 12, 2012 19:49
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 19:54
OpenCFD release OpenFOAMŪ version 1.7.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 August 26, 2010 12:40
Diesel combustion simulation ( Heat release rate) venkatesh Siemens 2 April 29, 2009 08:38
Public Release of the Wiki Jonas Larsson CFD-Wiki 3 November 7, 2005 05:13
