Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Extend Project 1.6-ext Binary Release for Mac OS X
Old   October 10, 2011, 08:42
Darrin Stephens
darrin is on a distinguished road
Philip,
In the file:
ThirdParty/rpmBuild/SOURCES/libccmio-2.6.1.patch_0
You need to add support for 11.0, this can be achieved by modifying lines 14 and 41 in the file. You need to modify line 14 as this is a new Darwin main version, different from 10.
Let me know if you need help. If you get this working can you post the issue and resolution on mantis so Martin can include in the hotfixes.
Darrin
darrin is offline   Reply With Quote
Old   October 10, 2011, 10:11
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Darrin,
Thanks for the help.
OK I am not quite sure how to modify the lines. At the moment lines 10-16 are:
@ -34,6 +34,7 @@
     x86_64-unknown-linux-gnu-null)     echo linux64_2.4-x86-glibc_2.2.5     ;;
     ppc64-unknown-linux-gnu-null)      echo linux64_2.6-pwr4-glibc_2.3.3    ;;
     i386-apple-darwin8-null)           echo i386-apple-darwin8              ;;
+    i386-apple-darwin10-null)          echo i386-apple-darwin10             ;;
     *)                                 echo unknown                         ;;
 esac
I changed it to:
@ -34,6 +34,7 @@
+    i386-apple-darwin11-null)          echo i386-apple-darwin11             ;;
     *)                                 echo unknown                         ;;
 esac
But then it gives out about a misformed patch.
Then the lines 36-45 are:
@@ -87,6 +87,9 @@
     i386-apple-darwin8.11.1)
+    i386-apple-darwin10.5.0 |  i386-apple-darwin10.7.0 | i386-apple-darwin10.8.0)
+       echo i386-apple-darwin10 ;;
         echo unknown
         echo System type ${SYSTEM} not supported! 1>&2 ;;
And I changed them to:
@@ -87,6 +87,9 @@
+    i386-apple-darwin11.0.0)
+       echo i386-apple-darwin11 ;;
         echo unknown
Is this OK?
Thanks,
Philip
bigphil is offline   Reply With Quote
Old   October 14, 2011, 10:46
bigphil's Avatar
Philip Cardiff
OK,
The compilation on Mac Lion runs fine now, I had to change two files:
ThirdParty/rpmBuild/SOURCES/libccmio-2.6.1.patch_0 and ThirdParty/rpmBuild/SPECS/libccmio-2.6.1.spec files
to include support for Mac Lion (darwin11).
I have reported this bug to mantis here.
I have attached a zip containing the patch and spec files that worked for me.
Philip
Old   April 7, 2012, 04:06
Jie
jiejie is on a distinguished road
Hi Hrvoje
Thanks for your instruction for compiling 1.6-ext on Mac. I followed your instruction and managed to compile it on Mac 10.6.5 (Snow Lepord) with one small change.
I removed -lrt at /OpenFOAM/OpenFOAM-1.6-ext/src/decompositionMethods/scotchDecomp/Make/options as Mac OS X doesn't need the dependency on "-lrt".
jiejie is offline   Reply With Quote
Old   August 27, 2013, 09:01
Default OpenFoam-1.6-ext Mac
  #25
loic tachon
lolo is on a distinguished road
Hi Im looking for this version of open foam for mac but your link for this version does not exists anymore.
Do you know where can I find this version ? (.dmg if it is possible)
Thanks a lot
Originally Posted by hjasak View Post
Binary release for Mac OS X
I have created a sparse disk image for OpenFOAM-1.6-ext and a Mac, available on Extend Sourceforge Download section.
This is what you do to use it:
1) download the dmg file
http://sourceforge.net/projects/openfoam-extend/files/ -> OpenFOAM-1.6-ext.dmg
2) double-click on it, to mount it
3) open a terminal and do the following
cd
mkdir OpenFOAM
cd OpenFOAM
ln -s /Volumes/OpenFOAM-1.6-ex .
and you are ready. Make yourself a run directory:
mkdir -p ~/OpenFOAM/<yourName>-1.6-ext/run
source the environment
. ~/OpenFOAM/OpenFOAM-1.6-ext/etc/bashrc
and you are ready to run.
Please report success/failure.
Compiling OpenFOAM-1.6-ext on a Mac
If you want to compile from scratch, find yourself a Mac (Yum!) and install XCode. The next steps are:
1) download and install wget
2) download and install rpm
3) download and install git
4) sort out malloc header link
cd /usr/include/
sudo ln -s malloc/malloc.h .
5) sort out gmake
cd /usr/local/
sudo ln -s /usr/bin/make gmake
6) install Paraview from dmg: we will use Paraview reader
7) Create a Casename-sensitive disk image (~10 GB, to be safe) and link it as above. Into the link image do a git checkout into it
8) cd ~/OpenFOAM/OpenFOAM-1.6-ext/etc ; cp prefs.sh-EXAMPLE prefs.sh
9) source the environment and compile all. You are in business!
Hope you'll find this useful. Happy McFoaming,
Hrv
lolo is offline   Reply With Quote
Old   November 5, 2013, 17:24
Eric Bryant
codder is on a distinguished road
I didn't realize an installation wiki page existed: http://openfoamwiki.net/index.php/In...enFOAM-1.6-ext
codder is offline   Reply With Quote
Old   November 5, 2013, 17:50
Retired Super Moderator
Bruno Santos
Greetings to all!
@codder:
Yep, but it's very recent! Check this thread for more information: http://www.cfd-online.com/Forums/ope...tain-lion.html
Best regards,
Bruno
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 19:54
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 09:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 16:52
