Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Hypersonic and Supersonic Flow Solvers
Like Tree10Likes
Old   May 30, 2020, 10:59
Vince
hyFoam is on a distinguished road
No, v1706 is the only version that can be used.
Thanks,
Vince
hyFoam is offline   Reply With Quote
Old   November 4, 2020, 09:26
Default Equilibrium constant calculation
  #22
Alexander Nekris
Neka is on a distinguished road
Hello Vincent,
first of all I would like to say that I like your work very much. I have written a similar solver but in a very light and immature version (compared to your project). My programming skills are unfortunately quite modest. My solver is based on sonicFoam instead of rhoCentralFoam, I wrote it based on foam-extend-4.0 and I use 3-temperature model for thermal non-equilibrium. I am not allowed to publish my solver yet. Besides, a lot of its parts are hard coded, which makes it rather user-unfriendly at the moment.
I am currently testing your hy2Foam solver. I have a question regarding chemistry. As I have seen in the chemical mechanisms in the hy2Foam tutorials, you calculate the forward reaction rate constant (k_f) in m^3/(kmole*s). Then you calculate the equilibrium constant K_eq by using the curve-fit coefficients in order to calculate k_b. But the unit of k_b can vary depending on the reaction. For example, the backward constant remains in m^3/(kmole*s) for such reactions as NO + O = O2 + N. This means that K_eq is in this case dimensionless. For reactions of type AB -> A + B, such as N2 + M = 2N + M, k_b is in m^6/(kmole^2*s). In this case K_eq is no longer dimensionless and gets the following dimensions: m^3/(kmole*s). Since the Arrhenius coefficients are mostly given in cm^3/(mole*s) or cm^6/(mole^2*s), you have to multiply K_eq by 1000 for the reactions of the type AB -> A + B in order to convert K_eq from CGS units to MKS units.
My question is: where does it happen in the source code?
Or did I make a mistake? Not sure, which is why I didn’t want to make a bug report.
Thanks in advance.
Kind Regards
Alexander
Neka is offline   Reply With Quote
Old   December 15, 2020, 14:17
Vince
Hi Alexander,
Thanks for your interest!
You did well by opening on Issue on hyStrath, I prefer when all questions are centralised there.
https://github.com/vincentcasseau/hyStrath/issues/59
Regards,
Vincent
Old   March 9, 2021, 19:48
anfho is on a distinguished road
Hello Vincent,
I am interested to do hypersonic simulations in OpenFoam. Thank you very much for your work on this, much appreciated. I tried to follow your links provided above:
- source code: https://github.com/vincentcasseau/hyStrath
- Wiki page: https://github.com/vincentcasseau/hyStrath/wiki
But they seem outdated. Is this solver still publicly available and would you please update.
Also, would this solver pair with the EOF-library: https://github.com/jvencels/EOF-Library, so that coupling to ELMER (https://www.csc.fi/fi/web/elmer) would be possible?
Thank you,
Andreas
anfho is offline   Reply With Quote
Old   March 9, 2021, 20:28
Vince
Hi Andreas,
The links are as follows now:
- source code: https://github.com/vincentcasseau/hyStrath (unchanged)
- website: https://vincentcasseau.github.io/ (replaced the Wiki)
I was not aware Elmer could be coupled to OpenFOAM. The solvers on hyStrath are no different from the OF ones so there is a chance it may work. If you are interested, please give it a try and open an Issue on hyStrath in case of conflicts.
Regards,
Vincent
Old   March 11, 2021, 13:47
Hi Vincent,
Thank you for your quick reply, much appreciated. We will try out hyStrath.
I have been doing some more digging and it seems Elmer is a great tool, but not directly suited for antenna simulations. What I am essentially interested in is plasma-RF interactions.
openEMS seems to be the right tool for antenna simulations: https://openems.de/start/ and can do bent patch antenna analysis: https://openems.de/index.php/Tutoria...h_Antenna.html, and the coupling can be one-way: hyStrath-->openEMS for example, unless you have a better suggestion for antenna simulations? I see you have done some work in MHD, but MHD problems are typically different from antenna problems.
Any useful information is appreciated.
Thank you!
Andreas
Old   March 14, 2021, 23:52
Vince
Hi Andreas,
Thanks for the short description and the links.
Unfortunately, I can't provide any advice about antennas.
Regards,
Vincent
cfd, hypersonic, openfoam, reacting, supersonic
Tutorial for highspeed flow (hypersonic) siimulations in ansys fluent rachitsigh11 ANSYS 1 December 19, 2016 03:54
Overflow in hypersonic flow simulation badboyz31 CFX 13 March 8, 2014 05:33
Hypersonic flow over a wedge Ravenn FLUENT 6 March 7, 2013 08:12
Supersonic flow simulation Tayfun FLUENT 4 June 12, 2004 10:31
