Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
OLAFOAM, the evolution of IHFOAM
Like Tree4Likes
Old   March 3, 2016, 10:29
Default OLAFOAM, the evolution of IHFOAM
Pablo Higuera
Phicau is on a distinguished road
Dear colleagues,
it is my pleasure to present a new numerical model based on the popular and widely used OpenFOAM: OLAFOAM.
OLAFOAM is the evolution of IHFOAM, a well-known three-dimensional Navier-Stokes solver for free surface flows, and is born with the spirit of providing the latest advances for the simulation of wave dynamics to the OpenFOAM and FOAM-extend communities. New implementations and updates will be readily available, bug fixes will be a priority and reasonable support will be given through the appropriate channels.
OLAFOAM provides cutting-edge technologies as state-of-the-art active wave generation and absorption techniques working at the boundaries (i.e. without increasing the computational cost), two phase flow through porous media or the newly introduced moving multi-paddle piston-type wavemakers, which also perform active wave absorption.
The release includes the complete source code, pre- and post-processing tools, 6 tutorials and additional reference materials. You can find all the details in the project web site:
https://sites.google.com/site/olafoamcfd/
Best regards,
Pablo Higuera
PhD in Civil Engineering, MSc
Research Fellow
National University of Singapore
elvis, kasra karimi, zanis and 1 others like this.
Phicau is offline   Reply With Quote
Old   March 4, 2016, 05:12
Diogo R.C.B. Neves
dneves is on a distinguished road
If you keep with the same development dynamics as IHFOAM I will be certainly be a OLAFOAM user
dneves is offline   Reply With Quote
Old   April 4, 2016, 03:25
ashkan is on a distinguished road
Hi Pablo,
Many thanks for your great work on IHFoam. I will download and start working wth your new olaFoam as well.
I found your wavemaker option very interesting and wanted to use that along with time series from wave tank. However, I was wondering if it is possible to model flap type wave makers as well or it only work with piston type wave makers?
Many thanks again
Ashkan
ashkan is offline   Reply With Quote
Old   April 4, 2016, 04:36
Pablo Higuera
Thanks Ashkan,
currently only piston type wavemakers are supported, but flap type is under development and I don't expect that it will take me long to polish it and release it.
I will keep you updated here: http://www.cfd-online.com/Forums/ope...am-thread.html
Best,
Pablo
Old   April 4, 2016, 04:39
Originally Posted by Phicau View Post
Thanks Ashkan,
Best,
Pablo
Thanks Pablo. Again thanks for your great work.
Ashkan
Old   April 17, 2016, 03:51
Mahdi Hashemi
smhashemi is on a distinguished road
Hi Pablo,
First, I'd like to thank you for your admirable work and support.
Actually I'm going to work with a cluster that OpenFOAM 3.0.1 is installed on it.
Unfortunately for now there is not any IHFOAM or OLAFOAM solver for this version of OpenFOAM.
With all respect, I wanted to know if there is any hope for the solver of version 3.0.1 to be released in the near future?
Best Regards,
Mahdi
smhashemi is offline   Reply With Quote
Old   April 17, 2016, 05:24
Pablo Higuera
Hi Mahdi,
try to compile the solver version 3.0.0. If I am not wrong, it should work. Otherwise, just let me know.
Best,
Pablo
Old   April 17, 2016, 08:52
Mahdi Hashemi
Hi Mahdi,
Best,
Pablo
Thank you Pablo,
I tried your opinion but the solver version 3.0.0 was not compiled on OF3.0.1.
I look forward to have your valuable comments.
Best regards,
Mahdi
Old   April 17, 2016, 23:23
Pablo Higuera
Hello again Mahdi,
there is a problem with your OpenFOAM installation, check/ask for a solution at the installation subforum. I have just tried and olaFoam compiles with no problems for OpenFOAM 3.0.1 (build 119cac7e8750).
Best,
Pablo
Old   May 26, 2016, 13:27
Julien Schaguene
JulienS is on a distinguished road
Hi Pablo,
First, I would like to thank you for the work you did on IHFoam (which I was trained to in Santander, good memories!) and now OlaFoam.
I recently installed OlaFoam on my cluster, with OpenFOAM v3.0+. All compiles nicely. But, it seems that there is a problem with IOobject constructor. "NO_READ" and "READ_IF_PRESENT" seems not to work anymore.
-> Error with NO_READ
--> FOAM FATAL ERROR:
NO_READ specified for read-constructor of object porosity of class IOobject
From function Foam::Istream& Foam::regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 46.
-> Error with READ_IF_PRESENT
--> FOAM FATAL IO ERROR:
cannot find file
file: [..]/run/Tutorials/olafoam/baseWaveFlume/0/porosityIndex at line 0.
Have you already encountered this problem?
Best regards
Julien
JulienS is offline   Reply With Quote
Old   May 26, 2016, 23:07
Pablo Higuera
Salut Julien,
thanks for your words and your bug report.
Since I don't work with v3.0+ I had not noticed this error before, I have just pushed the fix to the repository, it should work now. It seems that the constructor is less permissive in this version and you need to specify the value and dimensions.
If you encounter any other flaws let me know.
Best regards,
Pablo
Old   May 27, 2016, 03:57
Julien Schaguene
Hi Pablo,
thank you for your quick response, it seems to work fine now.
Best regards
Julien
Old   June 11, 2016, 23:19
Default mass balance olaFoam
  #13
Theo Moura
theogrm is on a distinguished road
Hi all,
I've been trying to simulate bichromatic wave groups propagating over a sloping beach using the irregular waveType. The problem I am having is the water level that is constantly increasing. I have in the waveDict both absGen 1 and absDir 0. Tried different combination with no success. Any hint will be appreciated.
Best Regards,
Theo
theogrm is offline   Reply With Quote
Old   July 13, 2016, 06:44
Default LES (Large Eddy Simulation) Model (LES type kEqn)
  #14
Ju Hyun Bae
kenneth0811 is on a distinguished road
Hi all
I am OLAFOAM user. I'd like to thank you for your admirable work and support. Through OLAFOAM i can learn a lot about the CFD analysis.
I used LES model in 2Dcase(RegularWave Stokes II). and I used blockMesh and SnappyHexMesh
but When I execute OLAFOAM, terminal show
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model kEqn
Selecting LES delta type smooth
Selecting LES delta type cubeRootVol
--> FOAM Warning :
From function cubeRootVolDelta::calcDelta()
in file LES/LESdeltas/cubeRooVolDelta/cubeRootVolDelta.C at line 55
Case is 2D, LES is not strictly applicable
Is it correct OLAFOAM exection? Although this FOAM Warning, OLAFOAM activated to the lasttime.
This is turbulenceProperties file , blockMeshDirt file in my case and ParaFoamView(using SnappyHexMesh refine).
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0)
(30 0 0)
(51.5 0 0)
(51.6 0 0)
(81.6 0 0)
(81.6 0 4)
(51.6 0 4)
(51.5 0 4)
(30 0 4)
(0 0 4)
(0 0 4.074)
(30 0 4.074)
(51.5 0 4.074)
(51.6 0 4.074)
(81.6 0 4.074)
(81.6 0 15.24089655)
(51.6 0 15.24089655)
(51.5 0 15.24089655)
(30 0 15.24089655)
(0 0 15.24089655)
(0 0.125 0)
(30 0.125 0)
(51.5 0.125 0)
(51.6 0.125 0)
(81.6 0.125 0)
(81.6 0.125 4)
(51.6 0.125 4)
(51.5 0.125 4)
(30 0.125 4)
(0 0.125 4)
(0 0.125 4.074)
(30 0.125 4.074)
(51.5 0.125 4.074)
(51.6 0.125 4.074)
(81.6 0.125 4.074)
(81.6 0.125 15.24089655)
(51.6 0.125 15.24089655)
(51.5 0.125 15.24089655)
(30 0.125 15.24089655)
(0 0.125 15.24089655)
blocks
hex (0 1 21 20 9 8 28 29) (240 1 32) simpleGrading (1 1 1)
hex (1 2 22 21 8 7 27 28) (172 1 32) simpleGrading (1 1 1)
hex (2 3 23 22 7 6 26 27) (1 1 32) simpleGrading (1 1 1)
hex (3 4 24 23 6 5 25 26) (240 1 32) simpleGrading (1 1 1)
hex (9 8 28 29 10 11 31 30) (240 1 1) simpleGrading (1 1 1)
hex (8 7 27 28 11 12 32 31) (172 1 1) simpleGrading (1 1 1)
hex (7 6 26 27 12 13 33 32) (1 1 1) simpleGrading (1 1 1)
hex (6 5 25 26 13 14 34 33) (240 1 1) simpleGrading (1 1 1)
hex (10 11 31 30 19 18 38 39) (240 1 88) simpleGrading (1 1 1)
hex (11 12 32 31 18 17 37 38) (172 1 88) simpleGrading (1 1 1)
hex (12 13 33 32 17 16 36 37) (1 1 88) simpleGrading (1 1 1)
hex (13 14 34 33 16 15 35 36) (240 1 88) simpleGrading (1 1 1)
// hex (24 25 37 36 31 30 42 43) (125 1 17) simpleGrading (1 1 1)
// hex (25 26 38 37 30 29 41 42) (80 1 17) simpleGrading (1 1 1)
// hex (26 27 39 38 29 28 40 41) (125 1 17) simpleGrading (1 1 1)
// hex (31 30 42 43 32 33 45 44) (125 1 31) simpleGrading (1 1 1)
// hex (30 29 41 42 33 34 46 45) (80 1 31) simpleGrading (1 1 1)
// hex (29 28 40 41 34 35 47 46) (125 1 31) simpleGrading (1 1 1)
edges
boundary
inlet
type patch;
faces
(0 20 29 9)
(9 29 30 10)
(10 30 39 19)
outlet
type patch;
faces
(4 24 25 5)
(5 25 34 14)
(14 34 35 15)
bottom
type wall;
faces
(0 1 21 20)
(1 2 22 21)
(2 3 23 22)
(3 4 24 23)
atmosphere
type patch;
faces
(19 18 38 39)
(18 17 37 38)
(17 16 36 37)
(16 15 35 36)
mergePatchPairs
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object turbulenceProperties;
simulationType LES;
LES
LESModel kEqn;
turbulence on;
printCoeffs on;
delta smooth;
cubeRootVolCoeffs
deltaCoeff 1;
PrandtlCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Cdelta 0.158;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
I do not English well. My post is quite a chaos. Sorry.
kenneth0811 is offline   Reply With Quote
Old   July 13, 2016, 22:26
Pablo Higuera
Hi Ju Hyun.
this is not exactly the best place for support, there is a dedicated post for that:
You are applying LES in 2D, which given its assumptions is not strictly applicable. For LES to be fully correct it needs to be applied in 3D.
Best,
Pablo
Old   July 14, 2016, 03:00
Ju Hyun Bae
Hi Ju Hyun.
Best,
Pablo
Hi Pablo.
I didn't know 'The OLAFOAM Thread'. I communicate by 'The OLAFOAM Thread' now.
and It is grateful that you gave an answer to my question.
Ju Hyun
Old   July 29, 2017, 19:54
Default Main differences between OLAFOAM and IHFOAM
  #17
Ahmed Elhanfi
Ahmed Elhanafi is on a distinguished road
Hi Pablo,
First of all, thank you for your support to OpenFOAM users. Could you please let me know what are the main differences between OLAFOAM and IHFOAM?
Kind regards,
Ahmed
Ahmed Elhanafi is offline   Reply With Quote
Old   July 30, 2017, 22:20
Pablo Higuera
Hi Ahmed,
thanks.
Some facts (as of 31/07/2017):
https://github.com/phicau/IHFOAM
First commit: Jul 8, 2014
Last commit: Feb 11, 2016
Number of commits: 21
Last solver included: OpenFOAM 3.0.0
Watch: 4 Star: 2 Fork: 6
https://github.com/IHFOAM/ihFOAM
First commit: Sept 30, 2015
Last commit: Jan 18, 2017
Number of commits: 8
Last solver included: OpenFOAM v1612+
Watch: 1 Star: 2 Fork: 3
Note: My name has been deleted from the code and has been replaced by Javier Lopez Lara and Gabriel Barajas
https://github.com/IHCantabria/ihFOAM
Last commit: Mar 21, 2017
Number of commits: 10
Watch: 2 Star: 0 Fork: 0
Note: Exactly the same as https://github.com/IHFOAM/ihFOAM, but with a new logo
For the record, they have integrated ihFoam in OpenFOAM+, with a fancier programming style, but they seem to have removed some wave theories and added others.
https://github.com/phicau/OLAFOAM
First commit: Mar 2, 2016
Last commit: Jul 3, 2017
Last solver included: OpenFOAM v1706+
Watch: 10 Star: 11 Fork: 5
Note: The first commit is exactly the same as the last commit of https://github.com/phicau/IHFOAM
Since I started developing olaFoam I have fixed bugs, updated the compatibility for new versions, added wave theories and the moving boundary wave generation module.
Best,
Pablo
Old   July 31, 2017, 05:25
Default Thanks
  #19
Ahmed Elhanfi
Hi Pablo,
Thank you for the detailed explanation. It is very much appreciated.
I have another subject to discuss. I have recently attended the ISOPE conference. During this event, a participant has mentioned in his paper that when using the inlet boundary conditions of IHFOAM a damping in wave height (wave height reduction) was observed when a turbulence model such as k-epsilon was implemented compared to a laminar model. I have observed the same damping issue with the k-epsilon turbulence model, but I found no wave damping when utilising SST k-w model. However, a recent paper published in Coastal Engineering Journal "Application of a buoyancy-modified k-ω SST turbulence model to simulate wave run-up around a monopile subjected to regular waves using OpenFOAM", found that there is a damping in wave height when using SST k-w model, and therefore the authors provided a solution of this by including a buoyancy term in the turbulent kinetic energy equation. I have emailed the authors of this paper asking about the turbulence model settings they have used to report such damping events, but they have not responded yet. I'm wondering if you have experienced this issue before with either IHFOAM or OLAFOAM.
Kind regards,
Ahmed
Old   July 31, 2017, 21:34
Pablo Higuera
Hi Ahmed,
it is well known that turbulence modelling does not work perfectly with transient two-phase flows in OpenFOAM. It was developed for other purposes and, therefore, you will sometimes produce a turbulence buildup that will damp the waves. The problem is not related with olaFoam or ihFoam, and it has been widely discussed in the forum, just make a quick search for it.
I suggest that if you have further questions, you can ask them in the support thread, as this one is quite hidden because of the dig-policy of this section of the forum.
https://www.cfd-online.com/Forums/op...am-thread.html
Best,
Pablo
coastal engineering, olafoam, waves
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 19:10
[IHFOAM] Error with IHFOAM version OF2300 in Mac androso OpenFOAM Community Contributions 3 February 7, 2017 15:06
IHFOAM Release Phicau OpenFOAM Announcements from Other Sources 2 June 2, 2015 08:42
IHFOAM - Wave generation with moving boundaries Phicau OpenFOAM Verification & Validation 0 May 18, 2015 05:53
Interfoam (OF 1.7) : pressure evolution, impact, 2D computation kassiotis OpenFOAM 2 December 21, 2010 16:09
