Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
New book: The OpenFOAM Technology Primer
Like Tree39Likes
Old   October 10, 2014, 15:07
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
When I tried to download the example and case files using git, I got the following error. I am wondering if any one here can post a solution. Thanks!
Pei-Ying
Cloning into 'primer-examples'...
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
phsieh2005 is offline   Reply With Quote
Old   October 11, 2014, 04:46
Tomislav Maric
tomislav_maric is on a distinguished road
Originally Posted by phsieh2005 View Post
Pei-Ying
Hi Pei-Ying,
the commands were wrong, this was my mistake. When you try to clone the git repository from bitbucket using
git clone git@bitbucket.org
bitbucket service expects you to have a configured SSH access to the server.
Try using these two commands instead:
git clone https://sourceflux@bitbucket.org/sourceflux/primer-examples.git
git clone https://sourceflux@bitbucket.org/sourceflux/primer-example-cases.git
and let me know if it works for you. I've tested them on a VM where I don't have SSH access to the bitbucket account and they are running on my side.
Thank you very much for the feedback!
Tomislav
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Old   October 11, 2014, 10:37
Pei-Ying Hsieh
Hi, Tomisla,
Thanks!
These 2 commands worked for me.
Pei-Ying
Old   October 11, 2014, 10:47
Pei-Ying Hsieh
Hi, Tomislav,
I am wondering if you can help me out with 2 things about the primer-examples.
1. On the installation page, it said using "./Allwcmake". I will assume that this is a type
cd primer-examples
. etc/bashrc
./Allwcmake
2. Allwmake failed compilation. I received a couple of errors (will attach below).
Am I missing anything? I am using the latest OpenFOAM-2.3.x from git.
Thanks!
Pei-Ying
phsieh@taipei:~/OpenFOAM/primer-examples> ./Allwmake
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file isoBubble.C
SOURCE=isoBubble.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/triSurface/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/surfMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/surfMesh/MeshedSurfaceProxy/ -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude  -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/isoBubble.o
'/home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/lib/libbubbleCalc.so' is up to date.
Making dependency list for source file tabulatedRigidBodyDisplacement/tabulatedRigidBodyDisplacementPointPatchVectorField.C
Making dependency list for source file recirculationControl/recirculationControlFvPatchFields.C
SOURCE=tabulatedRigidBodyDisplacement/tabulatedRigidBodyDisplacementPointPatchVectorField.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/fileFormats/lnInclude  -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/tabulatedRigidBodyDisplacementPointPatchVectorField.o
SOURCE=recirculationControl/recirculationControlFvPatchFields.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/fileFormats/lnInclude  -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/recirculationControlFvPatchFields.o
'/home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/lib/libprimerBoundaryConditions.so' is up to date.
Making dependency list for source file interpolatedSplineViscosityModel/interpolatedSplineViscosityModel.C
SOURCE=interpolatedSplineViscosityModel/interpolatedSplineViscosityModel.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I.. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/interpolatedSplineViscosityModel.o
'/home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/lib/libprimerTransportModels.so' is up to date.
Making dependency list for source file primerFunctionObjects/wettedCellsFunctionObject/wettedCellsFunctionObject.C
Making dependency list for source file cppFunctionObjects/fieldCellSet/fieldCellSet.C
SOURCE=primerFunctionObjects/wettedCellsFunctionObject/wettedCellsFunctionObject.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/wettedCellsFunctionObject.o
SOURCE=cppFunctionObjects/fieldCellSet/fieldCellSet.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/fieldCellSet.o
'/home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/lib/libprimerFunctionObjects.so' is up to date.
Making dependency list for source file dynamicSolidBodyMotionRefinedFvMesh/dynamicSolidBodyMotionRefinedFvMesh.C
SOURCE=dynamicSolidBodyMotionRefinedFvMesh/dynamicSolidBodyMotionRefinedFvMesh.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude  -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/dynamicSolidBodyMotionRefinedFvMesh.o
dynamicSolidBodyMotionRefinedFvMesh/dynamicSolidBodyMotionRefinedFvMesh.C: In member function ‘virtual bool Foam::dynamicSolidBodyMotionRefinedFvMesh::update()’:
dynamicSolidBodyMotionRefinedFvMesh/dynamicSolidBodyMotionRefinedFvMesh.C:132:18: error: no matching function for call to ‘Foam::dynamicSolidBodyMotionRefinedFvMesh::changing(bool)’
     changing(true);
dynamicSolidBodyMotionRefinedFvMesh/dynamicSolidBodyMotionRefinedFvMesh.C:132:18: note: candidate is:
In file included from /home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/fvMesh.H:50:0,
                 from /home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude/dynamicFvMesh.H:39,
                 from /home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude/dynamicRefineFvMesh.H:71,
                 from dynamicSolidBodyMotionRefinedFvMesh/dynamicSolidBodyMotionRefinedFvMesh.H:45,
                 from dynamicSolidBodyMotionRefinedFvMesh/dynamicSolidBodyMotionRefinedFvMesh.C:31:
/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/polyMesh.H:516:18: note: bool Foam::polyMesh::changing() const
             bool changing() const
/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude/polyMesh.H:516:18: note:   candidate expects 0 arguments, 1 provided
make: *** [Make/linux64GccDPOpt/dynamicSolidBodyMotionRefinedFvMesh.o] Error 1
Making dependency list for source file testDebugging.C
Making dependency list for source file testFieldCellSet.C
Making dependency list for source file testProfiling.C
Making dependency list for source file testSmartPointers.C
SOURCE=testProfiling.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/testProfiling.o
SOURCE=testSmartPointers.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -fno-elide-constructors -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/testSmartPointers.o
SOURCE=testFieldCellSet.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/primer-examples/src/lnInclude  -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/testFieldCellSet.o
SOURCE=testDebugging.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/testDebugging.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/testProfiling.o -L/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib \
     -lfiniteVolume -lOpenFOAM -ldl   -lm -o /home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/bin/testProfiling
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -fno-elide-constructors -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/testSmartPointers.o -L/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib \
     -lfiniteVolume -lOpenFOAM -ldl   -lm -o /home/phsieh/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/bin/testSmartPointers
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/testDebugging.o -L/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib \
     -lfiniteVolume -lOpenFOAM -ldl   -lm -o /home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/bin/testDebugging
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/primer-examples/src/lnInclude  -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/testFieldCellSet.o -L/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib \
     -L/home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/lib -lfiniteVolume -lmeshTools -lprimerFunctionObjects -lOpenFOAM -ldl   -lm -o /home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/bin/testFieldCellSet
Making dependency list for source file isoSurfaceBubbleCalculator.C
SOURCE=isoSurfaceBubbleCalculator.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/triSurface/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/surfMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/home/phsieh/OpenFOAM/primer-examples/src/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/isoSurfaceBubbleCalculator.o
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/triSurface/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/surfMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -I/home/phsieh/OpenFOAM/primer-examples/src/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/isoSurfaceBubbleCalculator.o -L/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib \
     -L/home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/lib -lfiniteVolume -ltriSurface -lsampling -lbubbleCalc -lOpenFOAM -ldl   -lm -o /home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/bin/isoSurfaceBubbleCalculator
Making dependency list for source file heatTransferTwoPhaseSolver.C
Making dependency list for source file scalarTransportDyMSolver.C
SOURCE=scalarTransportDyMSolver.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/scalarTransportDyMSolver.o
SOURCE=heatTransferTwoPhaseSolver.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/twoPhaseMixture/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/transportModels -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/incompressible/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/transportModels/interfaceProperties/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/turbulenceModels/incompressible/turbulenceModel -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/heatTransferTwoPhaseSolver.o
In file included from heatTransferTwoPhaseSolver.C:101:0:
pEqn.H: In function ‘int main(int, char**)’:
pEqn.H:12:9: error: ‘ddtPhiCorr’ is not a member of ‘Foam::fvc’
       + fvc::ddtPhiCorr(rAU, rho, U, phi)
In file included from heatTransferTwoPhaseSolver.C:66:0:
/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
 scalar maxDeltaT =
make[1]: *** [Make/linux64GccDPOpt/heatTransferTwoPhaseSolver.o] Error 1
make[1]: Target `/home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/bin/heatTransferTwoPhaseSolver' not remade because of errors.
make: *** [heatTransferTwoPhaseSolver] Error 2
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/finiteVolume/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/fvOptions/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/meshTools/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/dynamicFvMesh/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/sampling/lnInclude -IlnInclude -I. -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OpenFOAM/lnInclude -I/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/scalarTransportDyMSolver.o -L/home/phsieh/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib \
     -lfiniteVolume -lfvOptions -lmeshTools -ldynamicMesh -ldynamicFvMesh -lsampling -lOpenFOAM -ldl   -lm -o /home/phsieh/OpenFOAM/phsieh-2.3.x/platforms/linux64GccDPOpt/bin/scalarTransportDyMSolver
make: Target `application' not remade because of errors.
Old   October 11, 2014, 12:10
Retired Super Moderator
Bruno Santos
Greetings to all!
@Pei-Ying:
If you visit the page for the repository: https://bitbucket.org/sourceflux/primer-examples - or read the file "README.mdown", it states this:
Originally Posted by https://bitbucket.org/sourceflux/primer-examples
The port to 2.3.x is currently underway - all libraries except primerDynamicFvMesh should run on both versions.
Which is pretty much refers to the error message you've gotten
Best regards,
Bruno
tomislav_maric likes this.
Old   October 11, 2014, 13:00
Pei-Ying Hsieh
Thanks Bruno!
I thought compilation will work, but, just cannot run the cases in 2.3.x. ok, i will try this in 2.2.x.
Pei-ying
Old   October 11, 2014, 15:31
Tomislav Maric
Hi, Tomislav,
Yes, it's a typo, I've fixed it, thanks for reporting it.
The second question was already answered by Bruno, thanks a lot Bruno!
Tomislav
wyldckat likes this.
Old   October 13, 2014, 09:58
Default Reporting errors for the OpenFOAM Technology Primer book
  #28
Tomislav Maric
Hi everyone,
we have been asked multiple times about reporting errors found in the OpenFOAM Technology Primer book. There is a web page dedicated for that, you can follow this link to get there.
We will port the reports we got via emails to that page and of course to the book as well.
We are using print-on-demand, so by reporting errors that you find in the book, you are helping us a great deal make the book better and better with every print cycle. Of course, readers that report errors will be credited on the Errata page and in the book as well.
Thanks again to all readers that have reported the errors so far!
Best regards,
Tomislav & Jens & Kyle
Old   October 21, 2014, 16:50
Pei-Ying Hsieh
Hi, Tomislav,
Any estimate when the library will work on OpenFOAM-2.3.x completely? Just wondering.
Pei-Ying
Old   March 23, 2015, 06:05
Tomislav Maric
Hi, Tomislav,
Pei-Ying
Hey Pei-Ying,
We will start working on that in April, you can follow the repository on bitbucket and you'll get a notification when we start working on the port.
Best regards,
Tomislav
Old   April 4, 2015, 00:18
Smile thanks
  #31
Haomin Yuan
yhaomin2007 is on a distinguished road
Tomislav, Kyle, Jens,
I really want to express my appreciation for your hard work on this book. It is really nice to have somebody willing to do this.
jhoepken likes this.
yhaomin2007 is offline   Reply With Quote
Old   April 11, 2015, 13:48
Default Availability on Amazon
  #32
AI
sherif35 is on a distinguished road
Congratulation on the release of this book. it's about time we have a book specifically for OpenFOAM.
My question is, initial post indicated the book will be available for sale on Amazon at some point, any idea when?
Thank you.
Ahmed
sherif35 is offline   Reply With Quote
Old   April 11, 2015, 13:56
Elvis
elvis will become famous soon enough
it is a self published book you can order the book via their web page not via amazon. Once they planned to sell in amazon but now they publish on their own
elvis is offline   Reply With Quote
Old   May 26, 2015, 17:04
seyyed
S.M.H is on a distinguished road
hido your book (The OpenFOAM Technology Primer) have a second valume ?
because i saw diffrent design for first page of it
S.M.H is offline   Reply With Quote
Old   May 27, 2015, 03:53
Elvis
I think they would announce that a 2nd Edition will be available
on one of the Social Media accounts https://www.facebook.com/pages/Sourc...49803251896541
https://twitter.com/sourceflux_de
https://plus.google.com/+SourcefluxD...cefluxDe/posts
The Cover of the Book I own looks like
https://www.facebook.com/24980325189...type=1&theater
S.M.H likes this.
Old   December 4, 2015, 08:55
Default Great work!
  #36
Akshay Kumar
Akshay is on a distinguished road
Hey guys
Awesome work on the book! I've been contemplating to buy it for quite a while now. Is there another version/edition of the book coming out anytime soon?
Akshay is offline   Reply With Quote
Old   December 4, 2015, 10:50
Tomislav Maric
Originally Posted by Akshay View Post
Hey guys
The next edition of the book will definitely not appear before May 2016 - so you have at least 6 months time to read the current version. We are working on other things and having difficulties with finding the time for writing. Writing eats up a lot of time, as well as preparing the tutorials and the code examples...same goes for the blog posts..
If anyone has any ideas on the topics they would like to see in the next edition, let us know in this thread.
The more likes your proposal gets here, the more likely it is we will consider it for the next edition.
Old   December 9, 2015, 08:37
Pei-Ying Hsieh
I purchased the first book. Enjoyed reading it.
For the next book, is it possible to consider gearing more toward industrial applications? That is, case studies, like centrifugal pump, interDyMFoam, DEM.
Thanks!
Pei-Ying
Old   December 9, 2015, 12:07
Tomislav Maric
Thanks!
Pei-Ying
The next edition will definitely be more oriented towards application. The first part of the book (the application part) represents only 1/3 of the book.
The question remains if we should use validation cases or show cases for the case studies. Show cases are easier to set up and describe, and for most platform elements they can be simplified severely.
This might be a nice approach for users that want to learn how a part of the platform works, without going through all the gory details of the validation process for a numerical method - another serious topic that I'm sure would not fit in a single book.
When you mention case studies, do you mean showcases that describe how to use for example the DEM, or are you referring to quantifiable comparisons to experiments - validation?
Old   December 9, 2015, 17:11
Pei-Ying Hsieh
Hi, Tomislav,
Cool!
>When you mention case studies, do you mean showcases that describe how to use for >example the DEM.
Yes, this is what I am thinking about. Maybe also include some discussion of why specific schemes/tolerances/turbulence model/BCs is applied.
It will be cool if there is some kind of repository for OpenFOAM cases. I have seen a lot of impressive OpenFOAM simulation on Youtube. But, they are simply animations. NO details of how they are setup. Virtually impossible to learn from them how to setup the same (or similar) simulation. It is too bad.
Pei-Ying
book, documentation, primer
Can't get data from OpenFoam to external solver using externalCoupled perry OpenFOAM Running, Solving & CFD 4 May 26, 2014 09:09
Best Book to Accompany OpenFOAM mgdenno OpenFOAM 5 May 25, 2012 22:35
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
OpenFOAM workshop in Milan errico OpenFOAM 9 August 17, 2008 12:37
