June 18, 2014, 17:17 |
Change of Bug-Tracker for openfoam-extend
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
Sourceforge will discontinue its support for the Mantis-Bugtracker on the 19th of June. This means that https://sourceforge.net/apps/mantisb...?page_number=1 will no longer be available. Sourceforge has provided a migration path and will provide backups of the last state of Mantis. Using these backups we will set up new bug-trackers on https://sourceforge.net/projects/ope...urce=directory . The procedure has been tested and no essential data from Mantis (including attachments) will be lost. Bug IDs will be the same but the URLs will change. Once the transition is finished (which should take less than a day) it will be announced here. This affects (amongst others) the bug-trackers for - foam-extend - swak4Foam - PyFoam - waves2foam
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
SnappyHexMesh bug or dict syntax change | wikstrom | OpenFOAM Bugs | 2 | January 13, 2009 13:47 |
Bug in layerAdditionRemoval change to OF15 mesh format | andersking | OpenFOAM Bugs | 2 | August 6, 2008 05:17 |
no enthalpy change across the momentum source | Atit Koonsrisuk | CFX | 2 | December 19, 2005 03:33 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
Bug in the DEFINE_ADJUST macro? | Senthil | FLUENT | 5 | September 3, 2002 23:26 |
