February 4, 2015, 12:28 |
#21 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Good afternoon,
I have been posed a strange question, and I would like to be confirmed, before I answer it. The background is that I am going to publish a paper based on work using the extend branch. During the proof-process with the publisher they have requested manufacturer information on the extend version of OpenFoam. My answer would be that the extend version is not registered with any company, individual, foundation, etc. Therefore, I would simply reply that it is a community driven branch of OpenFoam (or something along those lines). Any comments are greatly appreciated. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
February 5, 2015, 03:31 |
#22 |
Hi Niels,
I guess that chapter "1 Overview" in the ReleaseNotes.txt is a pretty precise information on the extend version of OpenFoam http://sourceforge.net/p/openfoam-ex...leaseNotes.txt 1 Overview ----------- The foam-extend project is a fork of the OpenFOAM速 open source library for Computational Fluid Dynamics (CFD). It is an open project welcoming and integrating contributions from all users and developers. Previously known as OpenFOAM速-dev and OpenFOAM速-extend, it contains bug fixes and performance improvements, as well as extensions and additional features provided by community contributors (see file ListOfContributors), http://sourceforge.net/p/openfoam-ex...OfContributors |
April 25, 2015, 09:29 |
foam-extend-3.1 citation
#23 |
Domenico
Rep Power: 12 |
I succesfully used foam-extend-3.1 for my masters' thesis work. Actually, I would like to know in which way I should cite your software distribution since I didn't find any clear reference for that. The last post was partially exhaustive because I'd like to know firstly if I should refer to "openFOAM-ext" or "foam-extend" or "openFOAM Extend". Thank you in advance, I really appreciated your work with this software. Regards |
April 26, 2015, 13:25 |
#24 |
Håkan Nilsson
Rep Power: 18 |
Refer to it as FOAM-extend, or if you include the version number: FOAM-extend-3.1. Håkan |
November 2, 2016, 09:35 |
Meaning of each branch/tag of foam-extend-3.1
#25 |
Thomas Oliveira
Rep Power: 12 |
After reading this post and OpenFOAM wiki (https://openfoamwiki.net/index.php/I...oam-extend-3.1), I am still not sure which branch/tag is right for me. Code:
git clone git://git.code.sf.net/p/openfoam-extend/foam-extend-3.1 foam-extend-3.1 cd foam-extend-3.1 git show-ref --head Code:
1dd681f6e9430f3a49b7b69caf99649b5f23cf86 refs/remotes/origin/master 6c0c77dee21ac095fb7b430dcf93a8f16e3ac412 refs/tags/3.1 7d8e040bf53d952f86a4f1c2ff073ab3c6abc006 refs/tags/3.1.1 094e842fc0b0285ca5e39aeb081fa9056dfefb94 refs/remotes/origin/nextRelease P.S.: A similar question regarding foam-extend-3.2 can be found here Kind regards, Thomas |
November 2, 2016, 09:54 |
#26 |
Håkan Nilsson
Rep Power: 18 |
"which branch/tag is best for you" depends on what you want. First I wonder if you would perhaps rather go for the most recent version of FOAM-extend. That is now in a new repository, in order to further separate the FOAM-extend for from the vanilla version: https://sourceforge.net/p/foam-extend/wiki/Home/ The most recent version is 4.0, which (unfortunately) resides under 3.2. Click on Git and choose foam-extend-3.2. You can see that there is a master branch, a nextRelease branch, and a tag 3.2. There is unfortunately no tag 4.0, but you can consider the nextRelease branch as the most recent 4.0 version. To get the most recent version you do the following: mkdir $HOME/foam cd $HOME/foam git clone git://git.code.sf.net/p/foam-extend/foam-extend-3.2 foam-extend-4.0 (note that it says 4.0 at the end) cd foam-extend-4.0 git checkout nextRelease Then you have the most recent source code, and you can use "git pull" to get updates. The rest is to compile it as usual. You can have a look at my installation instructions here: https://pingpong.chalmers.se/public/...o?item=3112079 Håkan Last edited by hani; November 3, 2016 at 03:05. |
November 2, 2016, 15:18 |
#27 |
Thomas Oliveira
Rep Power: 12 |
Dear Håkan,
Thank you for your reply and for the link to the installation instructions. The link, however, is protected by a login page of Chalmers University. I have summarized my conclusions about the relationship between those branches and tags in another post. Kind regards, Thomas |
November 3, 2016, 03:07 |
#28 |
Håkan Nilsson
Rep Power: 18 |
I updated the link in my previous post. It seems like I get different URL's if I am logged in to our learning platform or if I am not logged in. The page is open to public.
Håkan |
November 7, 2016, 08:07 |
#29 |
Thomas Oliveira
Rep Power: 12 |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam-news-announcements-other/137520-release-foam-extend-3-1-a.html
Posted By | For | Type | Date | |
Untitled document | This thread | Refback | December 16, 2014 19:18 | |
Untitled document | This thread | Refback | November 6, 2014 05:31 | |
Untitled document | This thread | Refback | July 2, 2014 05:26 | |
Untitled document | This thread | Refback | June 26, 2014 05:45 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
