Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Vehicle aerodynamic study preprocessor
Old   February 7, 2014, 02:40
Default Vehicle aerodynamic study preprocessor
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
I am just releasing a web-portal to enable application specific CFD analysis pre-processing and/or cloud based analysis. It can be used to generate a complete openFoam case setup based on geometry (STL or SketchUp format), speed and yaw angle.
It is a freemium model:
- openFoam case generation is free. You upload the geometry and nominate the parameters. We do a bit of geometry cleaning and preparation, set up the openFoam case and send you an email with the openFoam setup files (no CFD simulation done). You can then run the simulation locally using openFoam. Note: swak4Foam is required; or
- you request that we run the CFD analysis for you (and we do some post-processing as well) for a nominal fee. Once the analysis is complete, you get an email with a link to download the CFD results in openFoam, as well as a few other post-processing format, and a link to a web page to view results.
The site URL is: https://cfdcloudengine.appspot.com/
Feedback would be very much appreciated.
julien.decharentenay is offline   Reply With Quote
Old   June 2, 2014, 11:05
minev
minev is on a distinguished road
Greetings Julien,
Is there any information on how much time do you need to perform calculations?
Offering CFD 'on demand' sounds very promising, and I would definitely use it.. do you have any case studies or available references?
In particular, I need a study of flow around a civil engineering block.
Regards,
Minev
minev is offline   Reply With Quote
Old   June 2, 2014, 18:46
Hi Minev,
Thanks for the message.
Turn-around time for the simulation is around 7 to 11 hours depending on calculator/how many simulation are in the queue and if the backend is fully operational (there are still downtime). You can check the backend status on the front webpage (just under the image).
I do not currently have case studies, but I ran two cases from AIJ http://www.aij.or.jp/jpn/publish/cfdguide/index_e.htm. The results are presented in http://www.slideshare.net/JuliendeCh...presentation-a. The presentation did have links to allow you to view the results through the portal, but these were removed in slideshare. I will post them here shortly.
You can register for 3 free trial simulations at https://cfdapps.appspot.com/registerfortrial.html to get a feel for it and whether it is suitable for your purposes. Remember, if you happen to use an incorrect geometry (scale, orientation, etc), send me an email with an amended geometry and I will restart the analysis.
Let me know how you go and if you need any assistance.
External Flow Aerodynamic Tanker Vehicle rzhang Main CFD Forum 0 February 3, 2014 01:23
Human Powered Vehicle Study robinfisichella Main CFD Forum 2 March 2, 2010 10:54
Launch vehicle aerodynamic coefficients B. Sulejmanovic Main CFD Forum 1 April 26, 2005 10:59
Pro-Am use for Aerodynamic Study Javidan Ahmad Siemens 0 February 22, 2005 13:57
CFD study for a MAV(Micro Air Vehicle) raj Main CFD Forum 3 June 14, 1999 21:29
