Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
OpenVSP Parametric Geometry Tool
Old   October 1, 2012, 20:56
Default OpenVSP Parametric Geometry Tool
Rob
rmcdo is on a distinguished road
FYI,
In January, a NASA parametric geometry tool, OpenVSP, was released as open source software. One of the primary uses of this tool is to feed CFD, so I'd like to reach out to various open source CFD communities to let them know it exists. To check it out, start at the main web site....
http://www.openvsp.org
VSP is not CAD. VSP abandons the ability for CAD to model truly arbitrary shapes. In exchange, VSP makes great strides in ease of use, flexibility, and speed. If you've been frustrated with CAD and your ability to model a geometry for CFD analysis, check VSP out.
VSP can be used to create watertight triangulated surfaces. In fact, there are two approaches to do this. First, VSP can perform a boolean union on a simple wireframe. Second, VSP will find the Bezier surface intersection curves and will generate an isotropic mesh on those surfaces.
The first mode is only appropriate for Cartesian methods. The second should be able to feed many volume mesh generators. VSP already writes out TetGen files, support for other volume generators is under development.
OpenVSP has been used very productively to feed Cart3D, a NASA Cartesian Euler code. There are some tutorials and documentation of that process available...
http://www.openvsp.org/wiki/doku.php?id=c3dtutorial
In addition, there is a general presentation about the file types that VSP can input/output. This presentation discusses the Cart3D workflows and goes into the mesh generation process in more detail.
http://www.openvsp.org/wiki/lib/exe/...es_meshing.pdf
Although VSP is targeted at airplanes, its ease of use has led people to use it for lots of things the developers never intended. As an open source project, we welcome all kinds of input and suggestions. In the medium term (~2 year) development plan, we will extend VSP to support user-defined components. This capability will transform VSP from an aircraft-specific tool to one that would handle any application with equal ease.
Rob
rmcdo is offline   Reply With Quote
Import geometry from CAD Giuseppe (Giuseppe) OpenFOAM Pre-Processing 34 December 14, 2017 17:24
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
2D geometry to 3D geometry Sgonzalezg ANSYS Meshing & Geometry 11 April 8, 2011 12:02
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 20:51
[GAMBIT] import terrain geometry cfdworker ANSYS Meshing & Geometry 2 May 24, 2009 22:40
