Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from Other Sources
Solid Mechanics Solvers added to OpenFOAM Extend
Like Tree36Likes
Old   December 31, 2016, 11:17
Mohammad Jam is on a distinguished road
Originally Posted by RLFerreira View Post
Hi Guys.
I'm trying to reproduce the HronTurekFsi3 tutorial from extend-bazaar. I installed those toolkits based on instructions from
HTML Code:
https://openfoamwiki.net/index.php/Extend-bazaar/Toolkits/Fluid-structure_interaction
for FOAM-extend-3.2. However, during hronTurekReport function object compilation rise an error to include "fluidStructureInterface.H". Above following warning msg from "log.fsiFoam".
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 124
    could not load libhronTurekReport.so: cannot open shared object file: No such file or directory
What can I do to fix it? I appreciate your helps. Thanks,
Ricardo.
Hi Ricardo,
I have similar problem! Did you find how to solve this error?
Other guys, any idea is welcome.
Best regards,
Mohammad Jam
joukovsky likes this.
Mohammad Jam is offline   Reply With Quote
Old   August 14, 2017, 08:20
sitajeje is on a distinguished road
Dear Philip,
Thank you very much for your contribution first of all!
I wonder whether you have a OpenFOAM4.0 Version of your code? I tried to compile and several errors appeared. I would appreciate greatly if you could update your code for the latest OF some time.
Thank you very much in advance!
Best regards,
sitajeje
sitajeje is offline   Reply With Quote
Old   September 29, 2017, 08:37
Raj
rajtilva is on a distinguished road
I want to slove "Simply Supported beam with UDL" using elasticSolidFoam. But I don't understand what BCs I should give at both ends ??
Sent from my Redmi Note 4 using CFD Online Forum mobile app
rajtilva is offline   Reply With Quote
Old   October 11, 2017, 12:41
tomdylan's Avatar
Tom Dylan
tomdylan is on a distinguished road
a while ago I found here a tool to extract the stress components sigmaxx, sigmaxy... from the computed stress tensor from the time levels.
I Think it was bigPhil how shared the tool.
Unfortunately I can't remember the tools name and so I can't find it
Any hints on this tool appreciated
tomdylan is offline   Reply With Quote
Old   October 11, 2017, 14:09
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Tom,
You can use the foamCalc utility to create a volScalarField field for each component of a vector/tensor/symmTensor volField e.g.
$> foamCalc components sigma
where '$>' represents the command prompt.
Philip
bigphil is offline   Reply With Quote
Old   October 12, 2017, 03:45
tomdylan's Avatar
Tom Dylan
Short command saves a lot manual work!
Thanks for that goodie!
Old   October 12, 2017, 05:01
Daniel Chrastina
shpalman is on a distinguished road
Send a message via Yahoo to shpalman Send a message via Skype™ to shpalman
I wrote myself a tool to calculate the strain components from the displacement field; this was useful to me since I have been using various versions of OpenFOAM over the years to model semiconductor nanostructures.
shpalman is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam-news-announcements-other/106881-solid-mechanics-solvers-added-openfoam-extend.html
Posted By For Type Date
Solid Mechanics Solvers added to OpenFOAM Extend - Page 4 -- CFD Online Discussion Forums This thread Refback September 16, 2013 11:14
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 18:55
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
OpenFOAM Version 1.4 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 April 11, 2007 19:56
Testing of OpenFOAM 1.4alpha Commenced OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 January 16, 2007 10:41
Testing of OpenFOAM 1.3alpha Commenced OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 February 7, 2006 08:31
