Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from ESI-OpenCFD
OpenFOAM Version 1.4.1 Released
Closed Thread
Old   August 3, 2007, 08:31
Default OpenFOAM Version 1.4.1 Released
OpenFOAM discussion board administrator
OpenCFD release OpenFOAM 1.4.1.
3 August 2007: OpenCFD are pleased to announce the release of version 1.4.1 of their OpenFOAM open source CFD toolbox.
OpenFOAM-1.4.1 is predominantly a patched version of the 1.4 release including some important bug-fixes, many of which were reported on the bugs-list on the discussion forum, but also includes some significant developments detailed below.
- Parallel running
OpenMPI-1.2.3 replaces LAM-7.1.2 as the default MPI used by OpenFOAM; LAM and other MPI implementations are still supported.
- Mesh/data conversion
New fluent3DMeshToFoam converter for 3D meshes from Fluent format to OpenFOAM format including full support for all BCs, zones etc.; new foamFormatConvert utility converts all OpenFOAM mesh and field files associated with a case into the format specified in the controlDict, e.g. converts binary files to ASCII and vice versa.
- Mesh motion
New turbDyMFoam solver for incompressible, turbulent flow of Newtonian fluids with moving mesh incorporating the PISO/SIMPLE/PIMPLE pressure-velocity solution algorithms; the icoDynFoam solver for incompressible, laminar flow of Newtonian fluids with moving mesh also modified with the PISO/SIMPLE/PIMPLE algorithms; mesh motion solvers extended to include velocity (as before) and displacement which are advantageous for periodic motion.
- Discretisation schemes
New filteredLinear2 scheme which removes high frequency modes with 'staggering' characteristics.
- GAMG solver
Improved handling of asymmetric matrices; smoothers for asymmetric matrices extended to include DILU and DILUGaussSeidel; completely replaces the old AMG solver (no longer supported); default solver for the coarsest matrix changed from direct to iterative, with direct solver can be selected using the optional directSolveCoarsest switch.
- Turbulence modelling
Implementation of the k-omega SST turbulence model for high-Re external and internal compressible flows (not fully tested).
- Other
Improvements to parallel compilation and optimisations for the Itanium2 processor.
For a full list of new features, see the Release Notes.
To download OpenFOAM 1.4.1 click here.
OpenCFD are Henry Weller, Mattijs Janssens, Chris Greenshields and Andy Heather.
Reproduced from original announcement, copyright (C) 2007 OpenCFD Ltd
Closed Thread
OpenFOAM Version 1.5 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 July 14, 2008 19:22
OpenFOAM Version 1.4 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 April 11, 2007 19:56
OpenFOAM Version 1.2 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 August 22, 2005 18:42
OpenFOAM Version 1.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 06:33
