Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from ESI-OpenCFD
OpenFOAM-v2206 released
Old   June 28, 2022, 05:17
Default OpenFOAM-v2206 released
OpenCFD
opencfd is on a distinguished road
New version of OpenFOAM-v2206
OpenCFD is pleased to announce the June 2022 release of OpenFOAMŪ v2206. This release extends OpenFOAM-v2112 features across many areas of the code. The new functionality represents development sponsored by OpenCFD's customers, internally funded developments, and integration of features and changes from the OpenFOAM community.
Among the new features users may find:
Pre-processing
  • snappyHexMesh improvements and optimisations
  • Improved createPatch utility
  • New setTurbulenceFields pre-processing utility
Numerics
  • Community contribution: New adjoint to k-omega SST model
  • Community contribution: updated adjoint optimisation
  • Improved QR decomposition algorithm
  • Improved semi-implicit sources
Solvers and physical models
  • New solid body mesh motion
  • New Reynolds-stress turbulence model: EBRSM
  • Improved wall functions
  • New tabulated anisotropic thermal conductivity solid transport
Boundary conditions
  • Improved turbulent digital filter condition
  • New outlet-mapped inlet condition
  • New specie adsoption conditions
Post-processing
  • Improved probes function object
  • Improved sampled surfaces
  • Improved runTimeControl function object
  • Improved Dynamic Mode Decomposition (DMD) tools
In addition to source code packages suitable for compilation on a variety of Linux and other POSIX systems, this release also has a number of pre-compiled binary packages.
  • Ubuntu Linux: packaged installation for Ubuntu 22.04 (LTS), 20.04 (LTS), 18.04 (LTS)
  • openSUSE Linux: packaged installation for Leap15.4, Leap15.3, Leap15.2
  • Redhat Linux variants: packaged installation for CentOS/Rocky 9, 8, 7 and Fedora 36, 35, ...
MS Windows users can use these packages and install them to Windows Subsystem for Linux or into a Linux container in Docker. Another possibility is to install cross-compiled executables directly to MS Windows.
Mac OSX users have to compile the source code using Clang compiler.
Full information about the release can be found at https://www.openfoam.com/news/main-news/openfoam-v2206
opencfd is offline   Reply With Quote
Old   July 6, 2022, 09:26
Joachim Herb
jherb is on a distinguished road
If I try to compile it, I get the following error:
Compile OpenFOAM libraries
    ln: OpenFOAM/lnInclude
    ln: OSspecific/POSIX/lnInclude
    found <sys/inotify.h>  --  enabling inotify for file monitoring.
wmake libo (POSIX)
wmake  dummy (mpi=INTELMPI)
wmake dummy
wmake  mpi (mpi=INTELMPI:intelmpi)
wmake mpi
wmake OpenFOAM
icpc -std=c++14 -pthread -fp-trap=common -fp-model precise -DOPENFOAM=2206 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-unknown-pragmas -diag-disable 327,654,1125,1292,2289,2304,11062,11074,11076 -O3  -DNoRepository  -I/data/projekte/OpenFOAMdev/OpenFOAM-v2206/build/linux64IccDPInt32Opt/src/OpenFOAM -DHAVE_LIBZ -iquote. -IlnInclude -I/data/projekte/OpenFOAMdev/OpenFOAM-v2206/src/OpenFOAM/lnInclude -I/data/projekte/OpenFOAMdev/OpenFOAM-v2206/src/OSspecific/POSIX/lnInclude   -fPIC -c db/IOstreams/Pstreams/IPBstreams.C -o /data/projekte/OpenFOAMdev/OpenFOAM-v2206/build/linux64IccDPInt32Opt/src/OpenFOAM/db/IOstreams/Pstreams/IPBstreams.o
Internal error loop: assertion failed: find_seq_in_lookup_table: seq_number not found (shared/cfe/edgcpfe/il.c, line 4275)
compilation aborted for db/IOstreams/Pstreams/IPBstreams.C (code 4)
make: *** [/data/projekte/OpenFOAMdev/OpenFOAM-v2206/wmake/rules/General/transform:35: /data/projekte/OpenFOAMdev/OpenFOAM-v2206/build/linux64IccDPInt32Opt/src/OpenFOAM/db/IOstreams/Pstreams/IPBstreams.o] Error 4
icpc --version
icpc (ICC) 19.0.3.199 20190206
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
mpirun --version
Intel(R) MPI Library for Linux* OS, Version 2019 Update 3 Build 20190214 (id: b645a4a54)
Copyright 2003-2019, Intel Corporation.
Has anybody seen this before?
Edit: With icpc (ICC) 2021.1.2 20201208 it is compiling. So it seems to be triggering a compiler problem/bug.
jherb is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
