August 16, 2012, 09:57 |
#21 |
Martin
Rep Power: 22 |
Hi Paula,
you should check the names of your blockMeshDict file: usually it is written with a lower "b", id est "blockMeshDict" and not "BlockMeshDict". You must call the blockMesh utility in the shell from within the case directory, in your case from "/home/termico/OpenFOAM/Paula-2.1.0/FOAM_RUN/MultiBlock". To be sure that the correct blockMeshDict file is used you can define it's location explicitly with Code:
blockMesh -dict /home/termico/OpenFOAM/Paula-2.1.0/FOAM_RUN/MultiBlock/constant/polyMesh/BlockMeshDict Martin |
August 17, 2012, 04:35 |
#22 |
Paula
Rep Power: 14 |
Hi Martin,
It seems to work... Thanks for your help!! Last edited by curiosity; August 17, 2012 at 05:23. |
September 22, 2012, 01:10 |
#23 |
Sangeeta
Rep Power: 14 |
Hello everybody,
I am also making blockMesh for multi blocks (In my case there are three rectangular solid blocks). As Martin mentioned above I have given different blocks names // Anode hex (0 1 9 8 4 5 13 12) Anode (100 80 50) simpleGrading (1.0 1.0 1.0) // Electrolyte hex (8 9 10 11 12 13 14 15) Electrolyte (100 50 50) simpleGrading (1.0 1.0 1.0) // Cathode hex (11 10 2 3 15 14 6 7) Cathode (100 50 50) simpleGrading (1.0 1.0 1.0) And run blockMesh first but when I am running splitMeshRegions -cellZones -overwrite, it is showing following error: Writing region per cell as volScalarField to "/home/sangeeta/elasticThermalSolidFoam/0/cellToRegion" Region Cells ------ ----- 0 400000 1 250000 2 250000 Region Zone Name ------ ---- ---- 0 0 Anode 1 1 Electrolyte 2 2 Cathode Sizes inbetween regions: Region Region Faces ------ ------ ----- 0 1 5000 1 2 5000 Reading volScalarField cellToRegion Adding patches Adding patches Inserting patch Anode_to_Electrolyte to slot 7 out of 7 --> FOAM Warning : From function gAverage(const UList<Type>&) in file /home/sangeeta/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/FieldFunctions.C at line 524 empty field, returning zero. --> FOAM FATAL ERROR: request for polyMesh Electrolyte from objectRegistry elasticThermalSolidFoam failed available objects of type polyMesh are 1 ( region0 ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/sangeeta/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140. FOAM aborting Anyone have any idea why this error is coming? I appreciate if anyone could help to fix this problem. Kind regards, Sangeeta |
September 23, 2012, 07:23 |
#24 |
Sorry for not replying for long times in here. But I guess, most of the problems luckily could be solved?
Concerning your question, Sargam: I had the same error myself recently. I am not completely sure, but could you check if you have all the zones (particularly "Electrolyte") within constant/regionProperties ? I think I was missing a zone in there which was asked for... If it was not that thing, I am sure it was a rather simple solution anyway - else I would remember it for sure! ;-) Please tell us if that was the point! |
September 23, 2012, 12:07 |
#25 |
Sangeeta
Rep Power: 14 |
Hi Bernhard,
thank you for the reply. Yes, I have all the zones (particularly "Electrolyte") within constant/regionProperties. Following is constant/regionProperties: FoamFile { version 2.0; format ascii; class dictionary; object regionProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solidRegionNames ( Anode Electrolyte Cathode ); pRef 100000; My blockMesh file is: convertToMeters 1; vertices ( (0.00025 0 0) (0.0005 0 0) (0.0005 0.000027 0) (0.00025 0.000027 0) (0.00025 0 0.0005) (0.0005 0 0.0005) (0.0005 0.000027 0.0005) (0.00025 0.000027 0.0005) (0.00025 0.000025 0) (0.0005 0.000025 0) (0.0005 0.000026 0) (0.00025 0.000026 0) (0.00025 0.000025 0.0005) (0.0005 0.000025 0.0005) (0.0005 0.000026 0.0005) (0.00025 0.000026 0.0005) ); blocks ( // Anode hex (0 1 9 8 4 5 13 12) Anode (100 80 50) simpleGrading (1.0 1.0 1.0) // Electrolyte hex (8 9 10 11 12 13 14 15) Electrolyte (100 50 50) simpleGrading (1.0 1.0 1.0) // Cathode hex (11 10 2 3 15 14 6 7) Cathode (100 50 50) simpleGrading (1.0 1.0 1.0) ); edges ( ); patches ( // From Bottom to Top patch Anode_Bottom ( (0 4 5 1) ) /* patch Anode_To_Electrolyte ( (3 7 6 2) ) patch Electrolyte_To_Cathod ( (9 11 10 8) )*/ patch Cathod_TOP ( (3 7 6 2) ) symmetryPlane left ( (0 4 12 8) (7 15 11 3) (8 12 15 11) ) patch Anode_right ( (1 5 13 9) ) patch Cathode_right ( (6 14 10 2) ) patch Electrolyte_right ( (9 13 14 10) ) patch frontAndBack ( (4 5 13 12) (13 14 15 12) (15 14 6 7) (0 1 9 8) (9 10 11 8) (11 10 2 3) ) ); mergePatchPairs ( ); In my blockMesh I am not able to define Anode_to_Electrolyte and Electrolyte_to_Cathode patches. When I define these patches it shows some error to run blockMesh. I am wondering how can I define these two patches? How can I fix this problem? Thanks in advance. Best regards, Sangeeta |
September 23, 2012, 13:49 |
#26 |
Okay, concerning the BCs to be defined in the blockMeshDict I don't know, because I do not know in which step they usually are created. But if I understand correctly, they are created automagically when running either blockMesh or splitMeshRegions. (I would guess for the latter one). So try to leave them out at first.
For the splitMeshRegions.... I would try to put in "fluidRegionNames ( );" into your regionProperties as well. I think that was the case with my problem one or two weeks ago. |
September 23, 2012, 16:10 |
#27 |
Sangeeta
Rep Power: 14 |
Hi Bernhard,
Thanks a lot for the reply. I have put "fluidRegionNames ( );" in regionProperties file but still following error is coming: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM Extend Project: Open source CFD | | \\ / O peration | Version: 1.6-ext | | \\ / A nd | Web: www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-ext-2467099e383a Exec : splitMeshRegions -cellZones -overwrite Date : Sep 23 2012 Time : 15:05:26 Host : sangeeta-laptop PID : 6371 Case : /home/sangeeta/elasticThermalSolidFoam nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Trying to match regions to existing cell zones. Number of regions:3 Writing region per cell file (for manual decomposition) to "/home/sangeeta/elasticThermalSolidFoam/constant/cellToRegion" Writing region per cell as volScalarField to "/home/sangeeta/elasticThermalSolidFoam/0/cellToRegion" Region Cells ------ ----- 0 400000 1 250000 2 250000 Region Zone Name ------ ---- ---- 0 0 Anode 1 1 Electrolyte 2 2 Cathode Sizes inbetween regions: Region Region Faces ------ ------ ----- 0 1 5000 1 2 5000 Reading volScalarField cellToRegion Adding patches Adding patches Inserting patch Anode_to_Electrolyte to slot 7 out of 7 --> FOAM Warning : From function gAverage(const UList<Type>&) in file /home/sangeeta/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/FieldFunctions.C at line 524 empty field, returning zero. --> FOAM FATAL ERROR: request for polyMesh Electrolyte from objectRegistry elasticThermalSolidFoam failed available objects of type polyMesh are 1 ( region0 ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/sangeeta/OpenFOAM/OpenFOAM-1.6-ext/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140. FOAM aborting Aborted Why this error is coming? Please let me know if you have any idea to fix this problem. Best regards, Sangeeta |
September 23, 2012, 18:52 |
#28 |
Okay, from this point onwards it is only guesswork from my side! I do not know a definite solution!
But what you could try: Remove the polyMesh-folders within the different part-regions. The only one remaining should be the one within case/constant/polyMesh. Then try again. Maybe the previous polyMesh-folders are blocking something. Afterwards do a new blockMesh and then the splitMeshRegions again. If it works post it in here and be happy. ;-) Another step for finding out if there is a problem with the procedure: Try to put in one of the regions into the fluidRegionNames-group. I do not know for sure if leaving a field blank does work with the 1.6-ext-release already. In any case then you will see if it is an error due to the splitMesh or if the problem is in the blockMesh already. But as I said: This is guessing from my side, so I wish you good luck in solving that problem! |
September 26, 2012, 17:57 |
#29 |
Sangeeta
Rep Power: 14 |
Hi Berhard,
Thank you for the reply. Sorry for the late reply. I do have only one polyMesh folder in constant directory. I think I am missing something in procedure. Now I am again doing it. Thanks, Sangeeta |
September 27, 2012, 08:50 |
#30 |
Unnikrishnan Mohankumar
Rep Power: 15 |
Dear Faomers,
I have the sample problem, I am using blockmesh to create my Multi Regions mesh and I am trying to create a Cylinder(solid) inside a Box(Air). hex (0 1 2 3 4 5 6 7) solid (20 20 30) simpleGrading (1 1 1) // Create Cylinder for solid hex (8 9 10 11 12 13 14 15) air (30 30 32) (1 1 1) // Creating a block for air I checked the constant/regionProperties. I have also set the region names correctly. I am not using setSet -batch batch.setSet and subsetMesh. As the edges of the Cylinder depend on the mesh and the Cells are not Split. The Mesh in the Box(air) and Cylinder(solid) are intersection. But 2 independent mesh. I wanted to know. if there is a option to Split the cells in Mesh in the Box(air) with the Cylinder(solid) which are create by same blockMesh file. Regards Unni attached Pictures of the box(air) & Cylinder(solid) blockMeshDict file FoamFile { version 2.0; format ascii; class dictionary; location "constant/polyMesh"; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( //Creating a cylinder which can be called as 'solid' (-1 0 0)//0 (0 -1 0)//1 (1 0 0)//2 (0 1 0)//3 (-1 0 3)//4 (0 -1 3)//5 (1 0 3)//6 (0 1 3)//7 // Creating a box outside the Cylinder and calling it 'air' (-1.5 -1.5 -0.2) // 8 (1.5 -1.5 -0.2) // 9 (1.5 1.5 -0.2) // 10 (-1.5 1.5 -0.2) // 11 (-1.5 -1.5 3.2) // 12 (1.5 -1.5 3.2) // 13 (1.5 1.5 3.2) // 14 (-1.5 1.5 3.2) // 15 ); blocks ( hex (0 1 2 3 4 5 6 7) solid (20 20 30) simpleGrading (1 1 1) // Creating a Cylinder for solid hex (8 9 10 11 12 13 14 15) air (30 30 32) (1 1 1) // Creating a block with air ); edges ( //Creating edges for Cylinder //If edges are not created the a cube would be formed instead of a cylinder. arc 0 1 (-0.707106781 -0.707106781 0) arc 1 2 (0.707106781 -0.707106781 0) arc 2 3 (0.707106781 0.707106781 0) arc 3 0 (-0.707106781 0.707106781 0) arc 4 5 (-0.707106781 -0.707106781 3) arc 5 6 (0.707106781 -0.707106781 3) arc 6 7 (0.707106781 0.707106781 3) arc 7 4 (-0.707106781 0.707106781 3) ); patches ( patch inner ( (0 1 2 3) (0 1 5 4) (1 2 6 5) (2 3 7 6) (3 0 4 7) (4 5 6 7) ) patch outer ( (8 9 10 11) (12 13 14 15) (8 12 15 11) (9 13 14 10) (8 12 13 9) (11 15 14 10) ) ) ; mergePatchPairs ( ); |
September 28, 2012, 07:59 |
#31 |
Rep Power: 15 |
@Sangeetha..
Did you solve your problem.. i think you have a file inside 0 folder with the name cellToRegion... i think this one consists only one set of region. That must be a reason. yours dint work. Do check. & also if you have any idea about my problem. Kindly check and reply. Regards Unni Last edited by unnikrsn; September 28, 2012 at 08:00. Reason: Spelling mistake.. hehehe |
September 28, 2012, 08:51 |
#32 |
Well, it is paramount for the chtMultiRegionFoam-solvers to find the subdirectories with the different regions.
So in case you do have no region-folders within constant, system and 0, it is already in the preparation that something has gone wrong. Did you define each of the blocks in the blockMeshDict to belong to one of the different regions? If not, try to do so! You will definitely need the setSet-step during preparation. As well I guess the splitMeshRegions-step is inavoidable during case preparation... If you really have one region only, you could try creating the different folders with these names and copying the complete polyMesh from constant to constant/fluidRegionName/polyMesh and do the same with the other files. |
September 28, 2012, 09:27 |
#33 |
Rep Power: 15 |
Dear Linse
No... I dint understand what you are saying. But i think you were givign a reply to Sangeetha Question ?? Could you please check my question and give me a reply. I am not planning to use Cellset.setSet at this stage as i have more than 100 Cylinder in a single Case file... Most of the Edges doesnt form a Cylinder because of the refinement in the blockMesh... so that is the only reason. i am planning to create my 100 Cylinders in blockMesh. Later use batch.setSet to define the region and split them using SplitMeshRegions. The Question asked is just for reference. with one Cylinder and one Box. Regards Unni |
October 1, 2012, 09:14 |
#34 |
Sorry, I think, some thoughts got mixed up in my last post. ;-)
@unnikrsn: I would suggest to try using the setSet without the -batch option. I GUESS then it tries to take the values from the blockMeshDict. I would not expect blockMesh to write the different mesh regions. I only would HOPE for setSet and splitMeshRegions to use the regions as they are defined within the blockMeshDict. But as I said: This is guessing from my side, I do not have definite solutions. @Sargam: Did you succeed already? |
October 2, 2012, 09:39 |
#35 |
Rep Power: 15 |
Dear Bernhard Linseisen
Thanks for you reply. I am working on it. when i get some success with it. I will post the pictures. Thanks & regards Unnikrishnan |
November 1, 2012, 18:49 |
#36 |
ak
Rep Power: 15 |
Sangeeta/Unni,
Were you able to resolve the problem? I am also getting: request for polyMesh heater from objectRegistry heatercase failed Kindly provide the solution if you were able to solve the issue, for the benefit of OF users. Thanks, ak |
November 2, 2012, 04:11 |
#37 |
Rep Power: 15 |
Hi Ak,
I checked the method, I am able to create 2 meshes with blockMesh. But i am still not able to split 2 meshes using Cellset.Setset and splitMesh. hex (0 1 2 3 4 5 6 7) solid (20 20 30) simpleGrading (1 1 1) // Create Cylinder for solid hex (8 9 10 11 12 13 14 15) air (30 30 32) (1 1 1) // Creating a block for air I dont think it is possible to seperate 2 intersecting blockMesh create using single blockMeshDict file. I also tried using stitchMesh, i get a mesh, with the intersecting area added twice to the new mesh. Kindly try the blockMeshDict file in this thread. http://www.cfd-online.com/Forums/ope...tml#post383907 Thanks & regards Unnikrishnan |
November 2, 2012, 12:32 |
#38 |
ak
Rep Power: 15 |
EDIT: I just realized that I had modified the solver previously - and checked now that the regionProperties files had not been compiled! It is working now (so far).
------------------------------------------------------ Thanks a lot for your reply. I'll try that approach as well. I've enclosed the case file (with the Allrun script). If you get a chance, could you please try and take a look/run the case? All commands run okay and appropriate region files are also generated, till I get to the solver chtMultiRegionFoam command. I use OF 1.7.1 Thanks! ak Last edited by newOFuser; November 2, 2012 at 12:48. |
May 20, 2013, 08:13 |
blockMesh
#39 | |
sandy
Rep Power: 13 |
Please I want to take your advice, could you please help me about doing blockMesh for my geometry as in the attached sketch. I am using OF 2.1.1, I have injector inside the combustion chamber, I have fuel inlet and air inlet and between these two inlets walls. Between air inlet and combustion chamber is wall. I constructed the geometry using blockMesh but I had problem in defining the internal walls for the injector then I found your post about naming blocks but I do not if it good for my case, please any thoughts,ideas would be very much helpful.. Sandy, |
May 20, 2013, 11:23 |
#40 | |
Yosmcer Mocktai
Rep Power: 17 |
So downer face is the outlet patch. Maybe giving your blockMeshDict file may help to advice you. It seems that other people already tried to have internal walls, hope this post can help: Internal walls of zero thickness Good luck with your design. |
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets | Struggle_Achieve | OpenFOAM Meshing & Mesh Conversion | 3 | June 17, 2019 10:29 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 17:59 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
