[snappyHexMesh] Add layers and deformation
Old   April 11, 2012, 19:27
Unhappy Add layers and deformation
Andrzej Prusiński
Prosiaczek is on a distinguished road
Hello Everyone
I'm encountering problem with meshing in snappyHexMesh, to be precise in step of adding layers. I'm trying to create a mesh of box with rods inside it and obtain 5 layers around those rods. As You can see in attached screenshots till the third step (adding layers) everything looks fine, but when snappyHexMesh adds layers to the rods surfaces, my box is getting deformed as You can see. Could someone look on my snappyHexMeshDict file and those pictures and said what I'm doing wrong?
I have 99 stl files of rods and box created by blockMesh.
Here is snappyHexMeshDict file:
http://speedy.sh/7PTEP/download/snappyHexMeshDict
P.S.
When I tried to add stl file with box, my mesh had something like damaged surface (like after pitting) due to not extruded cells. That's why I abandoned that idea and tried to create mesh without box saved in stl file.
Pictures for meshing without box in stl file:
Pictures for meshing with box in stl file:
Last edited by Prosiaczek; April 12, 2012 at 06:33. Reason: I forget to add link to snappyHexMeshDict file
Prosiaczek is offline   Reply With Quote
addlayer, deformation, pitting, snappyhexmesh
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 16:17
A question on "Specifying Boundary Layer Deformation Smoothing" didiean FLUENT 2 January 16, 2012 22:39
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 11:00
[snappyHexMesh] Extruding layers in snappy deforms internal geometry overkligheten OpenFOAM Meshing & Mesh Conversion 1 April 7, 2010 09:21
