[snappyHexMesh] fatal flex scanner internal error
Old   April 6, 2012, 11:03
Default fatal flex scanner internal error
Duncan Weatherhead
duncan21187 is on a distinguished road
Hi there, I have just tried running sHM around an stl file with fairly simple geometry and it fails, quoting the error "fatal flex scanner internal error" don't suppose anyone might be able to offer any suggestions as to the cause?
duncan21187 is offline   Reply With Quote
Old   September 19, 2013, 04:20
Vishal
inf.vish is on a distinguished road
Hey,
I am facing the same problem. How did you solve it?
inf.vish is offline   Reply With Quote
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
