[Commercial meshers] Icem cfd multidomain mesh conversion
Old   March 9, 2012, 04:27
Default Icem cfd multidomain mesh conversion
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
I have a mesh constisting of 3 domains. Each of them are connected by one interface in icemcfd. I want to use the MRFSimpleFoam, so I export the mesh in Fluent V6format, and run the fluentMeshToFoam. However, the conversion fails. Here is the error message. Any suggestion?
Best,
Attila
--> FOAM FATAL ERROR:
Cannot find match for first face. cell model: tet first model face: 3(1 2 3) Mesh faces:
4
0()
0()
0()
0()
    From function create3DCellShape(const label cellIndex, const labelList& faceLabels, const labelListList& faces, const labelList& owner, const labelList& neighbour, const label fluentCellModelID)
    in file create3DCellShape.C at line 185.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::error::abort() in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 in "/software/oss/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/fluentMeshToFoam"
#4  __libc_start_main in "/lib64/libc.so.6"
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   March 9, 2012, 05:44
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Maybe if you try flutent3DMeshToFoam instead of fluentMeshToFoam?
Also, exporting each domain separately to separate cases and then merging the meshes and stitching them is an option (using mergeMeshes and stitchMesh).
Philip
bigphil is offline   Reply With Quote
Old   May 2, 2013, 12:03
waiter120 is on a distinguished road
Hello, for everyone. I want share my solution of converting ICEM CFD hex mesh to OpenFOAM mesh.
This was found thanks to this amazing forum and all of its users.
So my recipe is like that.
1. Prepare mesh in ICEM CFD with all name selections
2. Export it to FLUENT_V6 (for my present experience, you don’t need specify BC in Output -> Boundary Condition (If I am wrong, please correct me))
3. Read mesh in FLUENT
4. Modify names of BC
4a. If you case is multi region (like chtMultiregionFoam). In FLUENT change type of coupled wall. From Wall to Interior (+ add interior- prefix to its name)
5. Change write-type to ascii “file/ binary-files? no”
6. Write .cas file
7. In OpenFOAM work directory
7a. fluentMeshToFoam –wrireZones fluent.cas
7b. splitMeshRegions -cellZones -overwrite
That’s ALL )))
waiter120 is offline   Reply With Quote
fluentmeshtofoam, icem cfd, mesh conversion
Import Mesh from ICEM CFD to CFX Andre Almeida CFX 16 April 19, 2016 04:42
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Export mesh from ICEM CFD for Fluent summerdream ANSYS 2 September 10, 2013 13:12
[ICEM] Problem with volume mesh in ICEM CFD kolapoasafa ANSYS Meshing & Geometry 2 September 16, 2011 04:54
Boddy fitted Hexcore Mesh in ICEM Cfd Mitch CFX 0 December 29, 2008 07:07
