March 7, 2012, 02:59 |
snappyhexmesh user guide
张德胜
Rep Power: 15 |
I am now learning snappyhexmesh ,but there are little paper to study.and i see the user guide ,but i can not download.If you have it,please give it to me .Thanks a lot.My e-mail is zhangdesheng0068@126.com.
March 7, 2012, 04:37 |
Disabled
Rep Power: 15 |
The user guide can be downloaded in pdf from
http://www.openfoam.org/docs/ There are several posts in the forum concerning snappyHexMesh, just use the search function first. You can also try some tutorials, such as the following in version 2.0.1 $FOAM_TUTORIALS/multiphase/LTSInterFoam/wigleyHull $FOAM_TUTORIALS/multiphase/interPhaseChangeFoam/cavitatingBullet $FOAM_TUTORIALS/heatTransfer/buoyantBoussinesqSimpleFoam/iglooWithFridges $FOAM_TUTORIALS/heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater $FOAM_TUTORIALS/mesh/snappyHexMesh/flange $FOAM_TUTORIALS/incompressible/windSimpleFoam/turbineSiting $FOAM_TUTORIALS/incompressible/simpleFoam/motorBike $FOAM_TUTORIALS/incompressible/pimpleDyMFoam/wingMotion/wingMotion_snappyHexMesh |
March 7, 2012, 06:04 |
张德胜
Rep Power: 15 |
Thanks a lot .anon_a,I have another question:after conduct snappyhexmesh,i should conduct the solver in which time .Tank you very much.
March 7, 2012, 06:11 |
Disabled
Rep Power: 15 |
If I understand correctly, you are wondering about the startTime that you must use after running sHM, because it produces several time directories. In fact, these directories contain the mesh in different stages.
I can think of the following two options: You may use "latestTime" in controlDict so that it uses the most complete version of the mesh (the last time directory). Or, you can call sHM with "snappyHexMesh -overwrite" so that the mesh is overwritten and you only have the initial conditions directory. In the latter case, you can use "startTime" in controlDict, as always. I always choose the second option to avoid confusion, unless I only want to check the differences between various grid stages. |
March 7, 2012, 06:23 |
张德胜
Rep Power: 15 |
You understand my question very correctly.If i choose the first opioion,i think i should copy some folder to the latest time folder.right?this folder should contain 0 folder.I hope you can give my fault.Thanks a lot.
March 7, 2012, 06:34 |
张德胜
Rep Power: 15 |
I understand it .Thank you very much.thanks.
guide, snappyhexmesh |
Incorrect utility names in User Guide | schoon | OpenFOAM Bugs | 1 | October 23, 2008 12:32 |
CFX User Guide query | siw | CFX | 0 | August 21, 2008 04:15 |
[blockMesh] BlockMesh documentation User Guide clearance of mergePatchPairs proposals | benru | OpenFOAM Meshing & Mesh Conversion | 0 | June 9, 2008 03:22 |
Ist it only me that cant read the user guide pdf | olle53 | OpenFOAM | 5 | April 5, 2006 23:14 |
Fluent 5.5. What the differences with fluent 5.3?? | confused | FLUENT | 2 | July 29, 2001 22:58 |
