[mesh manipulation] startFace problem using stitchMesh
Old   March 2, 2012, 15:59
Smile startFace problem using stitchMesh
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
I have a domain with 3 regions. I created the mesh in ICEM CFD and exported to fluent .msh format in three different parts. After that I converted the three parts using fluent3DMeshToFoam. Then I merged the meshes using mergeMeshes. This was because I want to use the AMI option and I want to have two interfaces.
Now I want to stitch this mesh to get rid of the interface to use MRFSimpleFoam. If I start the stichMesh -perfect command, I'm getting the following error:
--> FOAM FATAL ERROR:
Problem : Patch IN starts at 33871512
Current face counter at 33701764
Are patches in incremental order?
    From function polyTopoChange::polyTopoChange(const polyMesh& mesh, const bool strict)
    in file polyTopoChange/polyTopoChange/polyTopoChange.C at line 2459.
FOAM aborting
the patch "IN" is the inlet boundary, so firstly I don't understand why the utility is dealing with it since I want to merge the interfaces what is obviously not the IN patch. On the other hand, if I modify the startFace number of IN to the displayed value, then comes the next patch and gives the same error. Since I have 45 faces it's not a great fun to modify all of it by hand, so do you know what/where is the problem in my process? Why did these number change?
Best,
Attila
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   April 10, 2012, 00:20
liping_he
liping_he is on a distinguished road
Hi Attila
I also want use the AMI boundary, and I have the same question as you met. did you solve it. I wish you can give me a detailed process about how to create mesh. Thanks very much in advance for your advice.
bestwish
liping
liping_he is offline   Reply With Quote
Old   April 12, 2012, 09:15
Attesz's Avatar
Attesz
Hi, the process depends on your meshing software. But as I wrote, create the mesh for your domain separately, and merge the mesh using mergeMeshes. You can also find sites about it, use google.
Concerning the counting problem, as I see it's just a warning and we can ignore it. It's the result of the merging step.
fluent3dmeshtofoam, startface, stitchmesh
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 20:50
Simulation of Radial Fan with simpleFoam MRF nash OpenFOAM Running, Solving & CFD 2 November 5, 2015 11:12
Problem with building geometry - concentric cylinders Rhoddwen OpenFOAM Pre-Processing 9 December 17, 2014 11:02
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 10:22
