[Commercial meshers] converting Fluent mesh to openfoam standard mesh |
May 23, 2016, 13:49 |
#21 |
Rep Power: 10 |
Hey Zinedine,
Thanks for your quick reply! This is what I get when I do checkMesh Create polyMesh for time = 0 Time = 0 Mesh stats points: 167512 internal points: 0 faces: 331555 internal faces: 164045 cells: 82600 faces per cell: 6 boundary patches: 8 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 82600 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology INLET_TOP 59 120 ok (non-closed singly connected) INLET_BOTTOM 59 120 ok (non-closed singly connected) OUTLET 118 238 ok (non-closed singly connected) WALL_STRAIGHT_TOP 324 650 ok (non-closed singly connected) WALL_STRAIGHT_BOTTOM324 650 ok (non-closed singly connected) WALL_WAVY_BOTTOM 713 1430 ok (non-closed singly connected) WALL_WAVY_TOP 713 1430 ok (non-closed singly connected) frontAndBackPlanes 165200 167512 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (1.688336 -3.224465 -0.1007603) (9.43028 3.224465 0.1007603) Mesh (non-empty, non-wedge) directions (1 1 0) Mesh (non-empty) directions (1 1 0) All edges aligned with or perpendicular to non-empty directions. Boundary openness (3.079742e-18 -5.752289e-17 -6.754386e-19) OK. Max cell openness = 2.319659e-16 OK. Max aspect ratio = 4.989274 OK. Minimum face area = 4.319345e-05. Maximum face area = 0.00416419. Face area magnitudes OK. Min volume = 8.704371e-06. Max volume = 3.492038e-05. Total volume = 1.330074. Cell volumes OK. Mesh non-orthogonality Max: 33.49753 average: 9.974007 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.4789947 OK. Coupled point location match (average 0) OK. Mesh OK. End I want to know what are units of my mesh. This is the bounding box dimensions of checkMesh Overall domain bounding box (1.688336 -3.224465 -0.1007603) (9.43028 3.224465 0.1007603). Now the numbers here are in m or mm? The geometry that I had created in solidWorks was initially in mm. I'm asking this because my boundary conditions will change accordingly. Thanks!! Ram |
May 23, 2016, 13:58 |
#22 |
Zinedine
Rep Power: 15 |
Hi Ram
As far as I understand the output is in m. Regards Zinedine |
May 23, 2016, 14:00 |
#23 |
Zinedine
Rep Power: 15 |
Hi again
Have you visualised your mesh using paraFoam for a quick check just to be sure. Regards Z. |
May 23, 2016, 14:14 |
#24 |
Rep Power: 10 |
I have checked in paraview as well...The numbers are correct. But I'm not sure about the units...It is showing 9.43 but whether it is mm or m I dont know
May 23, 2016, 14:27 |
#25 |
Zinedine
Rep Power: 15 |
Hi agsin
I guess it is in m Regards Z. |
June 27, 2016, 00:58 |
fluentMeshToFoam not working (openFOAM)
#26 |
narayana vekamulla
Rep Power: 10 |
i am validating one paper, i asked my friend to send mesh from ansys. its a 2D geometry. fluentMeshToFoam temp.msh i got the following
narayana@narayana-Lenovo-G50-80:~$ cd /home/narayana/cavity narayana@narayana-Lenovo-G50-80:~/cavity$ fluentMeshToFoam temp.msh /*---------------------------------------------------------------------------*\\ | ========= | | | \\\\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\\\ / O peration | Version: 2.4.0 | | \\\\ / A nd | Web: www.OpenFOAM.org | | \\\\/ M anipulation | | \\*---------------------------------------------------------------------------*/ Build : 2.4.0-f0842aea0e77 Exec : fluentMeshToFoam temp.msh Date : Jun 26 2016 Time : 21:23:00 Host : "narayana-Lenovo-G50-80" PID : 3078 Case : /home/narayana/cavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time FINISHED LEXING dimension of grid: 0 Creating shapes for 3-D cells Building patch-less mesh...done. for a trial i used icoFoam. my solver is buoyantBoussinesqSimpleFoam. in the constant folder i found boundary file that consists of only zero value. what should i do ? |
March 28, 2017, 05:01 |
problem in fluentMeshToFoam conversion
#27 |
Bharadwaj Bhushan
Rep Power: 9 |
hi friends,
I am trying to convert .msh file to openfoam using both fluentMeshToFoam and fluent3DMeshToFoam. But I am getting an error in both the cases. fluentMeshToFoam - Found end of section in unknown ,Embedded blocks in comment or unknown: fluent3DMeshToFoam - Do not understand the characters: on line 1 please can anybody let me know how to solve this Thank you |
March 28, 2017, 07:19 |
#28 | |
Ricky
Rep Power: 12 |
is your ".msh" mesh file in binary or ascii format?
If it is easy, then something is fishy! |
March 29, 2017, 04:46 |
#29 |
yining song
Rep Power: 10 |
syn@syn-Lenovo:~$ fe32
syn@syn-Lenovo:~$ cd /home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system/ syn@syn-Lenovo:~/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system$ fluentMeshToFoam 1.msh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.2 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 3.2-334ba0562a2c Exec : fluentMeshToFoam 1.msh Date : Mar 29 2017 Time : 16:31:08 Host : syn-Lenovo PID : 3648 CtrlDict : "/home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system/system/controlDict" Case : /home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot open file file: /home/syn/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 61. FOAM exiting syn@syn-Lenovo:~/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole/system$ can you help me ? Yining Song |
March 29, 2017, 04:59 |
#30 |
Bharadwaj Bhushan
Rep Power: 9 |
March 29, 2017, 05:10 |
#31 | |
Ricky
Rep Power: 12 |
That seems to be the problem, as far as I know your ".msh" file should be in ASCII format.
fluentMeshToFoam 1.msh Code:
syn@syn-Lenovo:~/solids4foamphilip/tutorials/nonLinGeomSolidFoam/plateHole$ Ricky
March 29, 2017, 05:59 |
#32 | |
Bharadwaj Bhushan
Rep Power: 9 |
oh cool, then will try it. Thank you kera. Yining Song syn1993530, I also experienced the same problem like you. One should be in the base directory to run the solver, not in any folder like 0 or constant or system. |
[Other] OpenFoam Mesh to Fluent Mesh, 2D | lordvon | ANSYS Meshing & Geometry | 1 | January 14, 2022 12:20 |
Fluent converting 'wall' to 'interior' BC for hybrid mesh | DarrenC | FLUENT | 8 | January 3, 2019 06:24 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[CAD formats] Converting .gtm mesh for use in OpenFOAM | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 0 | December 20, 2012 17:17 |
