[snappyHexMesh] Number of cells/points in mesh and field don't match
Like Tree10Likes
Old   March 11, 2024, 07:54
Pedro Gouveia
unilord is on a distinguished road
Hey everyone.
I am simulating a transient analysis of a centrifugal pump using the sliding mesh approach (dynamic mesh) for my masters thesis. I am using the results of a steady state analysis as initial conditions for this transient simulation. I ran around 0.46 seconds (4.7 rotations of the impeller) and I am facing an issue when postprocessing the data in paraview.
First of all, I have this error when I firstly open the paraview:
 ERROR: In vtkOpenFOAMReader.cxx, line 8816
vtkOpenFOAMReaderPrivate (0x634e420): Number of cells/points in mesh and field do not match: mesh = 0, field = 13952 in Up, li { white-space: pre-wrap; }
Second, I have not an interpolated result for the velocity. Only the results in the centroids.
I believe this is due to the fact that I am using a sliding mesh. If anyone has any idea of why this might be happening, I would be truly grateful. I believe it has to do with the fact that I am using a dynamic mesh.
Best Regards,
Pedro Gouveia
unilord is offline   Reply With Quote
Old   May 29, 2024, 08:32
bravecaveman777 is on a distinguished road
Originally Posted by aghora17 View Post
found the solution into some Allrun files.
you just need to run: snappyHexMesh -overwrite and it will take care of the problem.
It works, very thanks!
bravecaveman777 is offline   Reply With Quote
Old   June 28, 2024, 05:45
Default Same problem sliding cyclic Mesh and NCC
  #23
okay to be anonymous
ExtRas is on a distinguished road
Dear foamers,
I got the same problem with the impeller tutorial of Openfoam 11 (.org). Mesh = 0, field = 320.
I prepared another case with a similar type of simulation (sliding mesh of a sixth of a fan, cyclic and NCC) and I got the same issue too.
The case is similar to the one presented by Pedro / Unilord two posts above.
Is it a bug ? Is there a workaround because it is quite annoying?
Best regards
Marc
PS: Ok it seams to have more answers here : Error in paraview results postprocessing regarding sliding mesh
ExtRas is offline   Reply With Quote
Old   June 28, 2024, 19:14
Pedro Gouveia
Originally Posted by ExtRas View Post
Dear foamers,
Best regards
Marc
Hey,
Yeah, that is my one man army thread ahahaha. But I did not actually find a solution, just a way to avoid it 😔
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 15:53
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
