[snappyHexMesh] Meshing 3D wing (hydrofoil) fails
Old   December 28, 2011, 15:26
Default Meshing 3D wing (hydrofoil) fails
Klaus
klausb will become famous soon enough
I am trying to mesh a 3D wing (hydrofoil). It's a symmetry case. The wing has a total span of about 1m hence the stl file represents half the wing.
The ultimate objective is to get lift and drag values for different versions of the wing. I tried to adapt the motorBike case as I'll be using the same turbulence model.
Blockmesh seems work fine but for some reason I am not able to mesh the domain/wing properly using snappyHexMesh.
I want to create a mesh refined with distance from the wing surface and I need a refined region at and behind the wing tip as winglets are an option to improve the lift/drag ratio.
How can I create such a mesh using snappyHexMesh?
1. How can I get the wing into the domain?
2. How can I mesh with a refinement based on surface distance?
3. How can I create the refined region at and behind the wing tip to capture the wing tip fortices?
Klaus
klausb is offline   Reply With Quote
[ANSYS Meshing] 3D wing blocking and meshing marcanyada ANSYS Meshing & Geometry 0 September 3, 2014 13:57
[GAMBIT] Meshing a s809 wing in Gambit yoooodarulez ANSYS Meshing & Geometry 33 July 24, 2013 03:49
meshing a wing sail linyx FLUENT 0 April 28, 2011 00:23
Wing meshing help...... ACER Main CFD Forum 0 January 31, 2011 19:20
Wing meshing 3d..... ACER ANSYS Meshing & Geometry 0 December 28, 2010 21:15
