[blockMesh] BlockMesh number internal faces and boundary |
December 4, 2011, 09:02 |
ynos
Rep Power: 15 |
Hi everyone
I have a Problem with blockMesh, there are 9 faces like lost or undefinied: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.0.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.0.1-51f1de99a4bc Exec : blockMesh Date : Dec 04 2011 Time : 13:54:32 Host : simon-VPCEB1J1E PID : 3622 Case : /home/simon/Escritorio/bloquemierda4 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/simon/Escritorio/bloquemierda4/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Reading patches section Creating block mesh topology Reading physicalType from existing boundary file Default patch type set to empty Check topology Basic statistics Number of internal faces : 75 The problem Number of boundary faces : 66 Number of defined boundary faces : 66 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 1 Writing polyMesh ---------------- Mesh Information ---------------- boundingBox: (-50 -20 -25) (15 20 5) nPoints: 39401 nCells: 36000 nFaces: 111300 nInternalFaces: 104700 ---------------- Patches ---------------- patch 0 (start: 104700 size: 1200) name: xmin patch 1 (start: 105900 size: 900) name: zmax patch 2 (start: 106800 size: 900) name: zmin patch 3 (start: 107700 size: 1200) name: ymax patch 4 (start: 108900 size: 1200) name: xmax patch 5 (start: 110100 size: 1200) name: ymin Attached the blokMeshDict Thanks in advanced /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.5 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } convertToMeters 1; vertices ( ( -50 20 -25) ( -50 20 -15) ( -50 5 -25) ( -50 5 -15) ( -50 20 -5) ( -50 5 -5) ( -50 20 0) ( -50 -5 -25) ( -25 20 -25) ( -50 -5 -15) ( -25 20 -15) ( -50 5 0) ( -25 5 -25) ( -50 20 5) ( -25 5 -15) ( -50 -5 -5) ( -25 20 -5) ( -50 5 5) ( -50 -5 0) ( -25 -5 -25) ( -25 20 0) ( -25 5 -5) ( -25 -5 -15) ( -25 5 0) ( -50 -5 5) ( -25 20 5) ( -50 -20 -25) ( -25 -5 -5) ( -50 -20 -15) ( -25 5 5) ( -25 -5 0) ( -50 -20 -5) ( -25 -5 5) ( -50 -20 0) ( -25 -20 -25) ( -25 -20 -15) ( -50 -20 5) ( 1 20 -25) ( -25 -20 -5) ( 1 20 -15) ( 1 5 -25) ( -25 -20 0) ( 1 5 -15) ( 1 20 -5) ( -25 -20 5) ( 1 -5 -25) ( 1 5 -5) ( 1 20 0) ( 1 -5 -15) ( 1 5 0) ( 1 20 5) ( 1 -5 -5) ( 1 5 5) ( 1 -5 0) ( 1 -5 5) ( 1 -20 -25) ( 15 20 -25) ( 1 -20 -15) ( 15 20 -15) ( 15 5 -25) ( 15 5 -15) ( 1 -20 -5) ( 15 20 -5) ( 1 -20 0) ( 15 -5 -25) ( 15 20 0) ( 15 5 -5) ( 15 -5 -15) ( 15 5 0) ( 1 -20 5) ( 15 20 5) ( 15 -5 -5) ( 15 5 5) ( 15 -5 0) ( 15 -5 5) ( 15 -20 -25) ( 15 -20 -15) ( 15 -20 -5) ( 15 -20 0) ( 15 -20 5) ); blocks ( hex (63 69 79 78 53 54 74 73) (10 10 10) simpleGrading (1 1 1) hex (53 54 74 73 49 52 72 68) (10 10 10) simpleGrading (1 1 1) hex (47 49 68 65 50 52 72 70) (10 10 10) simpleGrading (1 1 1) hex (61 63 78 77 51 53 73 71) (10 10 10) simpleGrading (1 1 1) hex (46 51 71 66 49 53 73 68) (10 10 10) simpleGrading (1 1 1) hex (43 46 66 62 47 49 68 65) (10 10 10) simpleGrading (1 1 1) hex (48 57 76 67 51 61 77 71) (10 10 10) simpleGrading (1 1 1) hex (42 48 67 60 46 51 71 66) (10 10 10) simpleGrading (1 1 1) hex (39 42 60 58 43 46 66 62) (10 10 10) simpleGrading (1 1 1) hex (54 69 44 32 53 63 41 30) (10 10 10) simpleGrading (1 1 1) hex (52 49 23 29 50 47 20 25) (10 10 10) simpleGrading (1 1 1) hex (52 54 32 29 49 53 30 23) (10 10 10) simpleGrading (1 1 1) hex (51 46 21 27 53 49 23 30) (10 10 10) simpleGrading (1 1 1) hex (46 43 16 21 49 47 20 23) (10 10 10) simpleGrading (1 1 1) hex (46 51 27 21 42 48 22 14) (10 10 10) simpleGrading (1 1 1) hex (46 42 14 21 43 39 10 16) (10 10 10) simpleGrading (1 1 1) hex (51 53 30 27 61 63 41 38) (10 10 10) simpleGrading (1 1 1) hex (48 51 27 22 57 61 38 35) (10 10 10) simpleGrading (1 1 1) hex (27 21 5 15 30 23 11 18) (10 10 10) simpleGrading (1 1 1) hex (32 30 18 24 29 23 11 17) (10 10 10) simpleGrading (1 1 1) hex (25 29 17 13 20 23 11 6) (10 10 10) simpleGrading (1 1 1) hex (21 16 4 5 23 20 6 11) (10 10 10) simpleGrading (1 1 1) hex (22 14 3 9 27 21 5 15) (10 10 10) simpleGrading (1 1 1) hex (14 10 1 3 21 16 4 5) (10 10 10) simpleGrading (1 1 1) hex (44 41 33 36 32 30 18 24) (10 10 10) simpleGrading (1 1 1) hex (41 38 31 33 30 27 15 18) (10 10 10) simpleGrading (1 1 1) hex (35 22 9 28 38 27 15 31) (10 10 10) simpleGrading (1 1 1) hex (45 55 75 64 48 57 76 67) (10 10 10) simpleGrading (1 1 1) hex (40 45 64 59 42 48 67 60) (10 10 10) simpleGrading (1 1 1) hex (37 40 59 56 39 42 60 58) (10 10 10) simpleGrading (1 1 1) hex (42 48 22 14 40 45 19 12) (10 10 10) simpleGrading (1 1 1) hex (42 40 12 14 39 37 8 10) (10 10 10) simpleGrading (1 1 1) hex (45 48 22 19 55 57 35 34) (10 10 10) simpleGrading (1 1 1) hex (19 12 2 7 22 14 3 9) (10 10 10) simpleGrading (1 1 1) hex (12 8 0 2 14 10 1 3) (10 10 10) simpleGrading (1 1 1) hex (34 19 7 26 35 22 9 28) (10 10 10) simpleGrading (1 1 1) ); edges ( ); patches ( patch xmin ( (26 28 9 7) (28 31 15 9) (31 33 18 15) (33 36 24 18) (7 9 3 2) (9 15 5 3) (15 18 11 5) (18 24 17 11) (2 3 1 0) (3 5 4 1) (5 11 6 4) (11 17 13 6) ) patch zmax ( (70 50 52 72) (50 25 29 52) (25 13 17 29) (72 52 54 74) (52 29 32 54) (29 17 24 32) (74 54 69 79) (54 32 44 69) (32 24 36 44) ) patch zmin ( (0 8 12 2) (8 37 40 12) (37 56 59 40) (2 12 19 7) (12 40 45 19) (40 59 64 45) (7 19 34 26) (19 45 55 34) (45 64 75 55) ) patch ymax ( (13 25 20 6) (25 50 47 20) (50 70 65 47) (6 20 16 4) (20 47 43 16) (47 65 62 43) (4 16 10 1) (16 43 39 10) (43 62 58 39) (1 10 8 0) (10 39 37 8) (39 58 56 37) ) patch xmax ( (56 58 60 59) (58 62 66 60) (62 65 68 66) (65 70 72 68) (59 60 67 64) (60 66 71 67) (66 68 73 71) (68 72 74 73) (64 67 76 75) (67 71 77 76) (71 73 78 77) (73 74 79 78) ) patch ymin ( (79 69 63 78) (69 44 41 63) (44 36 33 41) (78 63 61 77) (63 41 38 61) (41 33 31 38) (77 61 57 76) (61 38 35 57) (38 31 28 35) (76 57 55 75) (57 35 34 55) (35 28 26 34) ) ); mergePatchPairs ( ); |
December 4, 2011, 11:14 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings ynos,
I'm going to recycle an old answer of mine: http://www.cfd-online.com/Forums/ope...tml#post316670 - post #2 Best regards, Bruno
December 5, 2011, 15:08 |
blockMesh run and crash
ynos
Rep Power: 15 |
Thanks Wildckat, i maked again the blockMesh and checking with the paraFoam -block, i think everything is ok but when i run have problems ans crash the solver, the solver and conditions are ok because i make other blockMesh and all is ok and run right, but i dont get know the problem in the new blockMesh
Attached both blockMesh Thanks in advanced for your time |
December 6, 2011, 08:56 |
Bruno Santos
Rep Power: 128 |
Hi ynos,
I'm sorry, but I'll only be able to try to look at this in a couple of days Good luck! Bruno
December 7, 2011, 05:17 |
ynos
Rep Power: 15 |
Ok Bruno, thanks for everything
December 12, 2011, 17:57 |
Bruno Santos
Rep Power: 128 |
Hi ynos,
Unfortunately I haven't been able to get any time to test your "blockMeshDict" to try and figure out what the problem is. Have you managed to fix the problem? Best regards, Bruno
December 13, 2011, 06:36 |
ynos
Rep Power: 15 |
Hi Bruno, i just check the blockMesh again and its ok, the problem was with high speed
Thanks for everythink Have a nice day |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 09:14 |
