November 24, 2011, 16:46 |
Layers in a curved surface
Patrick Pazour
Rep Power: 14 |
Dear Forum Users,
After solving the problem with converting, there is just another task. First of all, i created the following body (simple pipe and a reducer): Code:
r = 10; h1 = 70; cl1 = 2; Point(1) = {0, 0, 0, cl1}; Point(2) = {r, 0, 0, cl1}; Point(3) = {-r, 0, 0, cl1}; Point(4) = {0, r, 0, cl1}; Point(5) = {0, -r, 0, cl1}; Circle(1) = {5, 1, 3}; Circle(2) = {3, 1, 4}; Circle(3) = {4, 1, 2}; Circle(4) = {2, 1, 5}; Extrude {0, 0, h1} { Line{2, 1, 4, 3}; Layers{20}; } Point(39) = {2, 15, 100, cl1}; Point(40) = {2, -15, 100, cl1}; Point(41) = {-2, 15, 100, cl1}; Point(42) = {-2, -15, 100, cl1}; Line(21) = {39, 41}; Line(22) = {41, 42}; Line(23) = {42, 40}; Line(24) = {40, 39}; Rotate {{0, 0, 1}, {0, 0, 0}, Pi/4} { Line{24, 21, 22, 23}; } Line(25) = {8, 39}; Line(26) = {6, 41}; Line(27) = {10, 40}; Line(28) = {9, 42}; Line Loop(29) = {2, 3, 4, 1}; Plane Surface(30) = {29}; Line Loop(31) = {22, 23, 24, 21}; Plane Surface(32) = {31}; Line Loop(33) = {27, 24, -25, 17}; Ruled Surface(34) = {33}; Line Loop(35) = {28, -22, -26, -9}; Ruled Surface(36) = {35}; Line Loop(37) = {13, 28, 23, -27}; Ruled Surface(38) = {37}; Line Loop(39) = {25, 21, -26, 5}; Ruled Surface(40) = {39}; Surface Loop(41) = {20, 30, 8, 40, 34, 38, 16, 12, 36, 32}; Volume(42) = {41}; There is just one question, do you have any ideas how to get similar layers (like from the extrusion) into the reducer? thanks Last edited by Artex85; December 18, 2011 at 08:41. |
December 18, 2011, 08:51 |
Solution for a complex body
Patrick Pazour
Rep Power: 14 |
Dear Forum Users,
After completing the simple body, i created a more complex one. Code:
// MESH cl = 2; // Globale Feinheit, wenn kein strukturiertes Mesh angegeben, sl1 = 10; // Meshnodes 1 sl2 = 9; // Meshnodes 2 ar = 0.8; // Verhältnis für den progressiven Verlauf la = 40; // Unterteilungen in Längsrichtung // PARAMETRISCHE ABMESSUNGEN D = 30; // Rohrdurchmesser Lr = 150; // Rohrlänge Ld = 25; // Diffusorlänge B = 35; // Diffusorbreite H = 5; // Diffusorhöhe R = 0.5 * D; // Radius Rohr x = R * Cos(45 * Pi / 180.); y = R * Sin(45 * Pi / 180.); xe1 = R * Cos((90-sl1/2) * Pi / 180.); ye1 = R * Sin((90-sl1/2) * Pi / 180.); xe2 = R * Cos((90+sl1/2) * Pi / 180.); ye2 = R * Sin((90+sl1/2) * Pi / 180.); F = 0.8; // Verkleinerungsfaktor Fh = 0.5; // Verkleinerungsfaktor Höhe // GEOMETRIE // Punkte für Rohr: Außenkontur Point(1) = {0, 0, 0, cl}; Point(2) = {x, y, 0, cl}; Point(3) = {-x, y, 0, cl}; Point(4) = {-x, -y, 0, cl}; Point(5) = {x, -y, 0, cl}; // Punkte für Rohr: Innenkontur Point(6) = {x*F, y*F, 0, cl}; Point(7) = {-x*F, y*F, 0, cl}; Point(8) = {-x*F, -y*F, 0, cl}; Point(9) = {x*F, -y*F, 0, cl}; // Punkte für Rohr: Innenkontur 2 Point(18) = {x*F^2, y*F^2, 0, cl}; Point(19) = {-x*F^2, y*F^2, 0, cl}; Point(20) = {-x*F^2, -y*F^2, 0, cl}; Point(21) = {x*F^2, -y*F^2, 0, cl}; // Punkte für Diffusor: Außenkontur Point(10) = {B/2, H/2, Ld, cl}; Point(11) = {-B/2, H/2, Ld, cl}; Point(12) = {-B/2, -H/2, Ld, cl}; Point(13) = {B/2, -H/2, Ld, cl}; // Punkte für Diffusor: Innenkontur Point(14) = {F*B/2, Fh*H/2, Ld, cl}; Point(15) = {-F*B/2, Fh*H/2, Ld, cl}; Point(16) = {-F*B/2, -Fh*H/2, Ld, cl}; Point(17) = {F*B/2, -Fh*H/2, Ld, cl}; // Punkte für Diffusor: Innenkontur 2 Point(22) = {F^2*B/2, Fh^2*H/2, Ld, cl}; Point(23) = {-F^2*B/2, Fh^2*H/2, Ld, cl}; Point(24) = {-F^2*B/2, -Fh^2*H/2, Ld, cl}; Point(25) = {F^2*B/2, -Fh^2*H/2, Ld, cl}; // Punkte für Inlet Point(26) = {xe1, ye1, -Lr, cl}; Point(27) = {xe2, ye2, -Lr, cl}; Point(28) = {xe1*F, ye1*F, -Lr, cl}; Point(29) = {xe2*F, ye2*F, -Lr, cl}; // Punkte für Restfläche Inlet Point(30) = {-xe1, -ye1, -Lr, cl}; Point(31) = {-xe2, -ye2, -Lr, cl}; Point(32) = {-xe1*F, -ye1*F, -Lr, cl}; Point(33) = {-xe2*F, -ye2*F, -Lr, cl}; // Volumen 1 Line(1) = {4, 12}; Line(2) = {12, 11}; Line(3) = {11, 3}; Line(4) = {4, 8}; Line(5) = {3, 7}; Line(6) = {16, 12}; Line(7) = {15, 11}; Line(8) = {15, 16}; Circle(9) = {8, 1, 7}; Circle(10) = {4, 1, 3}; Line(11) = {8, 16}; Line(12) = {7, 15}; Transfinite Line{1,2,3,8,9,10,11,12} = sl1; Transfinite Line{4,5} = sl2; Transfinite Line{6,7} = sl2; Line Loop(13) = {6, 2, -7, 8}; Line Loop(15) = {10, 5, -9, -4}; Line Loop(17) = {11, 6, -1, 4}; Line Loop(19) = {11, -8, -12, -9}; Line Loop(21) = {10, -3, -2, -1}; Line Loop(23) = {7, 3, 5, 12}; Ruled Surface(14) = {13}; Transfinite Surface{14} = {16,15,11,12}; Ruled Surface(16) = {15}; Transfinite Surface{16} = {8,4,3,7}; Ruled Surface(18) = {17}; Transfinite Surface{18} = {16,12,4,8}; Ruled Surface(20) = {19}; Transfinite Surface{20} = {7,8,16,15}; Ruled Surface(22) = {21}; Transfinite Surface{22} = {12,11,3,4}; Ruled Surface(24) = {23}; Transfinite Surface{24} = {15,11,3,7}; Recombine Surface{14,16,18,20,22,24}; Surface Loop(25) = {22, 16, 24, 14, 18, 20}; Volume(26) = {25}; Transfinite Volume{26}={16,12,11,15,8,4,3,7}; // Volumen 2 Circle(27) = {8, 1, 9}; Circle(28) = {4, 1, 5}; Line(29) = {9, 5}; Line(30) = {9, 17}; Line(31) = {5, 13}; Line(32) = {13, 17}; Line(33) = {17, 16}; Line(34) = {12, 13}; Transfinite Line{27,28,30,31,33,34} = sl1; Transfinite Line{-29} = sl2; Transfinite Line{32} = sl2; Line Loop(35) = {28, -29, -27, -4}; Line Loop(37) = {28, 31, -34, -1}; Line Loop(39) = {27, 30, 33, -11}; Line Loop(41) = {30, -32, -31, -29}; Line Loop(43) = {33, 6, 34, 32}; Ruled Surface(36) = {35}; Transfinite Surface{36} = {9,5,4,8}; Ruled Surface(38) = {37}; Transfinite Surface{38} = {5,4,12,13}; Ruled Surface(40) = {39}; Transfinite Surface{40} = {9,17,16,8}; Ruled Surface(42) = {41}; Transfinite Surface{42} = {17,13,5,9}; Ruled Surface(44) = {43}; Transfinite Surface{44} = {17,13,12,16}; Recombine Surface {36,38,40,42,44}; Surface Loop(45) = {38, 36, 42, 40, 44, 18}; Volume(46) = {45}; Transfinite Volume{46}={17,13,12,16,9,5,4,8}; // Volumen 3 Circle(47) = {9, 1, 6}; Circle(48) = {5, 1, 2}; Line(49) = {2, 6}; Line(50) = {2, 10}; Line(51) = {6, 14}; Line(52) = {14, 17}; Line(53) = {10, 13}; Line(54) = {10, 14}; Transfinite Line{47,48,50,51,53,52} = sl1; Transfinite Line{49} = sl2; Transfinite Line{54} = sl2; Line Loop(55) = {48, 49, -47, 29}; Line Loop(57) = {51, -54, -50, 49}; Line Loop(59) = {51, 52, -30, 47}; Line Loop(61) = {50, 53, -31, 48}; Line Loop(63) = {53, 32, -52, -54}; Ruled Surface(56) = {55}; Transfinite Surface{56} = {6,2,5,9}; Ruled Surface(58) = {57}; Transfinite Surface{58} = {6,2,10,14}; Ruled Surface(60) = {59}; Transfinite Surface{60} = {6,14,17,9}; Ruled Surface(62) = {61}; Transfinite Surface{62} = {2,5,13,10}; Ruled Surface(64) = {63}; Transfinite Surface{64} = {14,10,13,17}; Recombine Surface {56,58,60,62,64}; Surface Loop(65) = {58, 60, 64, 62, 56, 42}; Volume(66) = {65}; Transfinite Volume{66}={17,14,10,13,9,6,2,5}; // Volumen 4 Circle(67) = {6, 1, 7}; Circle(68) = {2, 1, 3}; Line(69) = {15, 14}; Line(70) = {11, 10}; Transfinite Line{67,68,69,70} = sl1; Line Loop(71) = {68, 5, -67, -49}; Line Loop(73) = {68, -3, 70, -50}; Line Loop(75) = {67, 12, 69, -51}; Line Loop(77) = {70, 54, -69, 7}; Ruled Surface(72) = {71}; Transfinite Surface{72} = {7,3,2,6}; Ruled Surface(74) = {73}; Transfinite Surface{74} = {3,2,10,11}; Ruled Surface(76) = {75}; Transfinite Surface{76} = {7,6,14,15}; Ruled Surface(78) = {77}; Transfinite Surface{78} = {15,11,10,14}; Recombine Surface {72,74,76,78}; Surface Loop(79) = {74, 72, 76, 78, 24, 58}; Volume(80) = {79}; Transfinite Volume{80}={15,11,10,14,7,3,2,6}; // Volumen 5-8 Extrude {0, 0, -Lr} { Surface{36, 16, 72, 56}; Layers{la}; Recombine; } // Volumen 9 Line(169) = {21, 20}; Line(170) = {21, 9}; Line(171) = {20, 8}; Line(172) = {21, 25}; Line(173) = {25, 24}; Line(174) = {24, 20}; Line(175) = {25, 17}; Line(176) = {24, 16}; Transfinite Line{169,172,173,174} = sl1; Transfinite Line{170,171} = sl2; Transfinite Line{175,176} = sl2; Line Loop(177) = {27, -170, 169, 171}; Line Loop(179) = {30, -175, -172, 170}; Line Loop(181) = {174, 171, 11, -176}; Line Loop(183) = {173, 176, -33, -175}; Line Loop(186) = {169, -174, -173, -172}; Ruled Surface(178) = {177}; Transfinite Surface{178} = {21,9,8,20}; Ruled Surface(180) = {179}; Transfinite Surface{180} = {21,25,17,9}; Ruled Surface(182) = {181}; Transfinite Surface{182} = {8,16,24,20}; Ruled Surface(184) = {183}; Transfinite Surface{184} = {25,17,16,24}; Ruled Surface(187) = {186}; Transfinite Surface{187} = {20,24,25,21}; Recombine Surface {178,180,182,184,187}; Surface Loop(188) = {178, 180, 184, 187, 182, 40}; Volume(189) = {188}; Transfinite Volume{189}={16,24,25,17,8,20,21,9}; // Volumen 10 Line(190) = {20, 19}; Line(191) = {19, 7}; Line(192) = {23, 24}; Line(193) = {23, 15}; Line(194) = {23, 19}; Transfinite Line{190,192,194} = sl1; Transfinite Line{191} = sl2; Transfinite Line{193} = sl2; Line Loop(195) = {171, 9, -191, -190}; Line Loop(197) = {190, -194, 192, 174}; Line Loop(199) = {194, 191, 12, -193}; Line Loop(201) = {176, -8, -193, 192}; Ruled Surface(196) = {195}; Transfinite Surface{196} = {20,8,7,19}; Ruled Surface(198) = {197}; Transfinite Surface{198} = {24,20,19,23}; Ruled Surface(200) = {199}; Transfinite Surface{200} = {23,15,7,19}; Ruled Surface(202) = {201}; Transfinite Surface{202} = {24,16,15,23}; Recombine Surface {196,198,200,202}; Surface Loop(203) = {182, 198, 196, 200, 202, 20}; Volume(204) = {203}; Transfinite Volume{204}={24,16,15,23,20,8,7,19}; // Volumen 11 Line(205) = {19, 18}; Line(206) = {18, 6}; Line(207) = {18, 22}; Line(208) = {22, 23}; Line(209) = {22, 14}; Transfinite Line{205,207,208} = sl1; Transfinite Line{206} = sl2; Transfinite Line{209} = sl2; Line Loop(210) = {205, 206, 67, -191}; Line Loop(212) = {51, -209, -207, 206}; Line Loop(214) = {205, 207, 208, 194}; Line Loop(216) = {208, 193, 69, -209}; Ruled Surface(211) = {210}; Transfinite Surface{211} = {19,7,6,18}; Ruled Surface(213) = {212}; Transfinite Surface{213} = {18,6,14,22}; Ruled Surface(215) = {214}; Transfinite Surface{215} = {22,23,19,18}; Ruled Surface(217) = {216}; Transfinite Surface{217} = {23,15,14,22}; Recombine Surface {211,213,215,217}; Surface Loop(218) = {211, 215, 213, 217, 76, 200}; Volume(219) = {218}; Transfinite Volume{219}={19,7,6,18,23,15,14,22}; // Volumen 12 Line(220) = {22, 25}; Line(221) = {18, 21}; Transfinite Line{220, 221} = sl1; Line Loop(222) = {221, 172, -220, -207}; Line Loop(224) = {209, 52, -175, -220}; Line Loop(226) = {206, -47, -170, -221}; Ruled Surface(223) = {222}; Transfinite Surface{223} = {18,22,25,21}; Ruled Surface(225) = {224}; Transfinite Surface{225} = {22,14,17,25}; Ruled Surface(227) = {226}; Transfinite Surface{227} = {18,6,9,21}; Recombine Surface {223,225,227}; Surface Loop(228) = {225, 223, 227, 180, 60, 213}; Volume(229) = {228}; Transfinite Volume{229}={18,6,9,21,22,14,17,25}; // Volumen 13 Line Loop(230) = {208, 192, -173, -220}; Line Loop(232) = {205, 221, 169, 190}; Ruled Surface(231) = {230}; Transfinite Surface{231} = {23,22,25,24}; Ruled Surface(233) = {232}; Transfinite Surface{233} = {19,18,21,20}; Recombine Surface {231,233}; Surface Loop(234) = {233, 198, 215, 187, 223, 231}; Volume(235) = {234}; Transfinite Volume{235}={23,22,25,24,19,18,21,20}; // Apply an elliptic smoother to the grid Mesh.Smoothing = 100; Physical Surface("HotWall") = {133, 155, 89, 111, 141, 119, 97, 163, 211, 233, 196, 178, 227}; Physical Surface("Inlet") = {146, 124, 102, 168}; Physical Surface("Outlet") = {14, 44, 64, 78, 202, 217, 184, 231, 225}; Physical Surface("ColdWall") = {74, 62, 38, 22}; Physical Volume("Flow") = {83, 82, 84, 81, 80, 219, 26, 204, 235, 229, 66, 189, 46}; |
interFoam, water flowing down a curved surface: is it correct? | be89 | OpenFOAM Running, Solving & CFD | 2 | April 21, 2017 13:22 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh | Elise | OpenFOAM Meshing & Mesh Conversion | 1 | April 22, 2013 02:32 |
flow rate through curved surface | john | Siemens | 0 | February 13, 2004 01:01 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
